We want to install the screenshot updates for CS5 Design Premium. Unfortunately, the first one we tried, AdobeBridge, asked for ApplicationManager, and when we tried to run that, it told us to run SupportAdvisor, which no longer exists.
Why is this happening, and how can we resolve it? We have Windows 7 Home Premium 64-bit, and our current CS5 components are:
Bridge CS5 | 4.0.5.11 | |
Content Viewer | Version unknown | |
Contribute CS5 (CS5... folder) | PDF... | |
Device Central CS5 | 3.0.1.0 | |
Digital Edition 3.0 | 3.0.0.0 | |
Dreamweaver CS5 | 11.0.4.4993 | |
Extension Mgr CS5 | 5.0.0.334 | |
Fireworks CS5 | 11.0.1.7 | |
Flash Builder 4 (CS5... folder) | PDF... | |
Flash Catalyst CS5 | Version unknown |
Flash Professional CS5 (CS5... folder) PDF...
Flash CS5 | 11.0.2.489 | ||
Illustrator CS5 | 15.0.2.399 | ||
InDesign CS5 | 7.0.4.553 | ||
Photoshop CS5 | 12.0.4.0 | ||
Utilities CS5 | Version unknown | ||
Widget Browser | Version unknown |
Thanks in advance!
update manually: http://www.adobe.com/downloads/updates/
That site is where we got the pictured files.
Here is the list, presented verbally and in reverse chronological order:
ApplicationManager8.0_all.exe
ApplicationManager8.0_all.zip
AdobeInDesign7_0_4Patch-All.zip
AdobeIllustrator_15.0.2.zip
FlashCS5_Update.zip
Fireworks_11.0.2_All_AdobeUpdate.zip
AdobeExtensionManager-5.0.1-mul-AdobeUpdate.zip
AdobeDreamweaver-11-0-All-Update.zip
DeviceCentral_2.1.1_mul_AdobeUpdate.zip
AdobeBridge_4.0.5_mul_AdobeUpdate.zip
Please see the original post for details about our problem.
Thanks for all help!
We want to install the screenshot updates for CS5 Design Premium. Unfortunately, at least AdobeBridge asked for ApplicationManager, and when we tried to run that, it told us to run SupportAdvisor, which no longer exists.
The files we downloaded from Product updates include:
FlashCS5_Update.zip
All help is appreciated. We need to USE CS5 Design Premium, not just have it take up space on our PC!
you could check your log files to see if there's a specific error, Troubleshoot with install logs | CS5, CS5.5, CS6, CC
otherwise, i don't see a practicable way how to help you via a forum.
The instructions at that location are confusing...
What options do we have if that set of instructions doesn't work, since CS5 is at least two versions prior to the current one (CC)?
are you stating, you can't find the log files?
No, although it took a few seconds to figure out what parts of the instructions should have followed each other.
We are asking what options we have for getting help if the logs don't provide an answer. From what we've noticed, the only options we have are either the forums or telephone, and telephone is not viable--Support probably won't answer anything about products from as far back as CS5 pre-CS5.5.
adobe doesn't support pre cs6 versions via telephone or otherwise.
kglad said, "otherwise, i don't see a practicable way how to help you via a forum."
That suggests there may be alterenatives. What would those be?
someone would need to work on your computer, in person or via the internet.
