2 Replies Latest reply on Feb 25, 2015 7:55 AM by Koen Van Riel
    adjustment layer: solid fill
    Koen Van Riel Level 1
      Hi I'm looking for a way to create an adjustment layer kind :"solid fill"  with applescipt.
      It should have a fill with an Lab color (eg; L= 20, a=10, b=13)
      Code:
         tell application "Adobe Photoshop CS3"
             tell current document
                set newLayer to make art layer with properties {name:"MyInkName", kind:solid fill layer, color:{class:Lab color, value_L:20, value_a:10, value_b:13}}
               end tell
        end tell
      error:
      You can only change the layer's kind to text or normal.
      Koen
        • 1. Re: adjustment layer: solid fill
          c.pfaffenbichler Level 9
          You may have to use the JavaScript code created with ScriptingListener.plugin.
          Why do you use AppleScript?
          • 2. Re: adjustment layer: solid fill
            I don't know java script.
            Also I get the lab values from an excel sheet with applescript.
            I found this java code but it needs the be changed:
            1) I want lab values and the this code generates an RGB color
            2) I need to input the lab values from applescript
            How can I do this?
            Tnx
            activate
              do javascript "var id115 = charIDToTypeID( \"Mk  \" );
                var desc21 = new ActionDescriptor();
                var id116 = charIDToTypeID( \"null\" );
                    var ref8 = new ActionReference();
                    var id117 = stringIDToTypeID( \"contentLayer\" );
                    ref8.putClass( id117 );
                desc21.putReference( id116, ref8 );
                var id118 = charIDToTypeID( \"Usng\" );
                    var desc22 = new ActionDescriptor();
                    var id119 = charIDToTypeID( \"Type\" );
                        var desc23 = new ActionDescriptor();
                        var id120 = charIDToTypeID( \"Clr \" );
                            var desc24 = new ActionDescriptor();
                            var id121 = charIDToTypeID( \"Rd  \" );
                            desc24.putDouble( id121, 9.999847 );
                            var id122 = charIDToTypeID( \"Grn \" );
                            desc24.putDouble( id122, 39.999390 );
                            var id123 = charIDToTypeID( \"Bl  \" );
                            desc24.putDouble( id123, 49.999237 );
                        var id124 = charIDToTypeID( \"RGBC\" );
                        desc23.putObject( id120, id124, desc24 );
                    var id125 = stringIDToTypeID( \"solidColorLayer\" );
                    desc22.putObject( id119, id125, desc23 );
                var id126 = stringIDToTypeID( \"contentLayer\" );
                desc21.putObject( id118, id126, desc22 );
            executeAction( id115, desc21, DialogModes.NO );"
            end tell
