20 Replies Latest reply on May 25, 2015 5:59 AM by rob day
    Stitch lines created in a PDF/X-1a due to transparency flattening during export from InDesign
    AWP64 Level 1
      Has there been any sure fire methods to avoid the digital stitch lines created in a PDF/X-1a due to transparency flattening during export from InDesign? If I attempt to edit the PDF using the Acrobat Edit Text and Graphics tool the PDF is actually carved into sectors and images are not selectable as a whole. Also contrary to what I have read those white lines do indeed image from time to time. I could export as PDF/X4 to preserve the transparency but on occasion it would be advantageous to flatten it before supplying to the printer. Currently using CC and have done the usual things in an attempt to avoid the lines such as all text above transparent objects on a separate layer and 'Clip-Complex-Region' on export.
      Thanks in Advance!
