13 Replies Latest reply on Feb 19, 2015 9:36 PM by HeavyWater007
    Weird audio issue going on with a MOV file used in project
    HeavyWater007
      So hoping someone has came across this and knows what's going on.
      I'm using AE CS6.  I have a quicktime movie that is a clip in my comp.  Comp has been rendered successfully in the past.  I've copied the folder containing the source files to a new hard drive and I've reinstalled my operating system.
      I go to edit this project that i've worked on previously, but when I go to render it out and playback the movie, the audio for the clip plays for about a minute just fine then it loops back to the beginning of the clip for a couple of seconds, then jumps back to current position then jumps to another point, all while the video plays like it should.
      So in the original comp, I use the source clip three times with it's respective audio.  I'm basically taking three different points in the clip. Each point on it's own layer.
      Some things i've done to try and troubleshoot.
      - I've checked the source mov file and it' plays perfectly.  No issues
      - I've double clicked on the source clip in the project list.  I then attempt to RAM preview it.  It plays for about a minute (about the threshold of RAM preview) and it loops/does it's wierd thing at the same point.
      - I've tried to delete the two layers, leaving just the single layer/clip and try to RAM Preview and wierd loop still occurs.
      - I've tried to Reload the source clip
      - I've tried to Copy the file/import the copy/replace footage of the source clip...still wierd loop occurs.
      - I've tried to delete the AE disk cache/delete windows temp files/reboot the computer...no joy.
      Kinda thinking my project is jacked and I'll have to McGuiver the video/audio to complete the final movie...
      Thoughts?
      Thanks in advance.
        • 1. Re: Weird audio issue going on with a MOV file used in project
          Without proper system information and other technical details like the actual file specs and render settings nobody can tell you much. You've written a lot, but provided very little usable info.
          Mylenium
          • 2. Re: Weird audio issue going on with a MOV file used in project
            HeavyWater007 Level 1
            Operating System System Model
            Windows 7 Ultimate (x64) Service Pack 1 (build 7601)
            Install Language: English (United States)
            System Locale: English (United States)
            No details available
            Processor a Main Circuit Board b
            2.80 gigahertz Intel Core i7 860
            32 kilobyte primary memory cache
            1024 kilobyte secondary memory cache
            8192 kilobyte tertiary memory cache
            64-bit ready
            Multi-core (4 total)
            Hyper-threaded (8 total)
            Board: ASUSTeK Computer INC. P7P55D-E LX Rev 1.xx
            Serial Number: MT7014K16000667
            Bus Clock: 133 megahertz
            BIOS: American Megatrends Inc. 1602 12/16/2010
            Drives Memory Modules c,d
            4060.57 Gigabytes Usable Hard Drive Capacity
            2590.56 Gigabytes Hard Drive Free Space
            ELBY CLONEDRIVE SCSI CdRom Device [Optical drive]
            HL-DT-ST BD-RE GGW-H20N ATA Device [Optical drive]
            OCZ-VERTEX2 [Hard drive] (60.02 GB) -- drive 1, s/n OCZ-A48O1MFG7S78F028, rev 1.29,SMART Status: Healthy
            ST2000DM001-1ER164 [Hard drive] (2000.40 GB) -- drive 2, s/n Z4Z0TNDC, rev CC25,SMART Status: Healthy
            WDC WD20EZRX-00D8PB0 [Hard drive] (2000.40 GB) -- drive 0, s/n WD-WCC4M3061065, rev 80.00A80, SMART Status: Healthy
            8192 Megabytes Usable Installed Memory
            Slot 'DIMM0' has 2048 MB
            Slot 'DIMM1' has 2048 MB
            Slot 'DIMM2' has 2048 MB
            Slot 'DIMM3' has 2048 MB
            Local Drive Volumes
            c: (NTFS on drive 1)59.91 GB30.94 GB free
            d: (NTFS on drive 2)524.29 GB485.24 GB free
            e: (NTFS on drive 0)2000.40 GB630.84 GB free
            f: (NTFS on drive 2)10.74 GB2.06 GB free
            g: (NTFS on drive 2)1465.24 GB1441.47 GB free
            Network Drives
            None discovered
            Printers
            Adobe PDF Converteron Documents\*.pdf
            Microsoft Shared Fax Driveron SHRFAX:
            Microsoft XPS Document Writeron XPSPort:
            Controllers Display
            ATA Channel 0 [Controller] (4x)
            ATA Channel 1 [Controller] (4x)
            Standard Dual Channel PCI IDE Controller (4x)
            AMD Radeon HD 6800 Series [Display adapter]
            hp L2335 [Monitor] (23.2"vis, s/n CNP416Z0R7, April 2004)
            Bus Adapters Multimedia
            Virtual CloneDrive
            Standard Enhanced PCI to USB Host Controller (2x)
            AMD High Definition Audio Device
            Z-10 USB Speaker
            Clip information:
            General Complete name : IMG_0584.
            MOV Format : MPEG-4
            Format profile : QuickTime
            Codec ID : qt
            File size : 311 MiB
            Duration : 4mn 6s
            Overall bit rate : 10.6 Mbps
            Recorded date : 2013-06-20T18:36:03-0700
            Encoded date : UTC 2013-06-21 01:36:03
            Tagged date : UTC 2013-07-05 03:54:55
            Writing application : 6.1.3
            Writing library : Apple QuickTime
            Model : iPhone 4
            Make : Apple
            Video ID : 1
            Format : AVC
            Format/Info : Advanced Video Codec
            Format profile : Baseline@L3.1
            Format settings, CABAC : No
            Format settings, ReFrames : 1 frame
            Format settings, GOP : M=1, N=24
            Codec ID : avc1
            Codec ID/Info : Advanced Video Coding
            Duration : 4mn 6s
            Source duration : 4mn 6s
            Bit rate : 10.5 Mbps
            Width : 1 280 pixels
            Height : 720 pixels
            Display aspect ratio : 16:9
            Frame rate mode : Variable
            Frame rate : 23.976 fps
            Minimum frame rate : 23.077 fps
            Maximum frame rate : 24.000 fps
            Color space : YUV Chroma subsampling : 4:2:0
            Bit depth : 8 bits
            Scan type : Progressive
            Bits/(Pixel*Frame) : 0.476
            Stream size : 309 MiB (99%)
            Source stream size : 309 MiB (99%)
            Title : Core Media Video
            Tagged date : UTC 2013-06-21 01:36:16
            Color primaries : BT.709
            Transfer characteristics : BT.709
            Matrix coefficients : BT.709
            Color range : Limited
            Audio ID : 2
            Format : AAC
            Format/Info : Advanced Audio Codec
            Format profile : LC
            Codec ID : 40
            Duration : 4mn 6s
            Bit rate mode : Constant
            Bit rate : 64.0 Kbps
            Channel(s) : 1 channel
            Channel positions : Front: C
            Sampling rate : 44.1 KHz
            Compression mode : Lossy
            Stream size : 1.88 MiB (1%)
            Source stream size : 1.88 MiB (1%)
            Title : Core Media Audio
            • 3. Re: Weird audio issue going on with a MOV file used in project
              Render Settings:
              Output module: format set to H.264
              Audio output checked.
              All other settings for rendering left at default.
              • 4. Re: Weird audio issue going on with a MOV file used in project
                And what is your full version number? "CS6" tells us that it starts with 11, but what are the numbers after that? Is it 11.0.4? If not, you should consider updating. You're missing out on the bug fixes!
                What version of QuickTime do you have installed?
                Have you ever installed any codec packs (such as K-Lite)? They can sometimes cause weird issues like this.
                • 5. Re: Weird audio issue going on with a MOV file used in project
                  11.0.0.378 (Guess having the latest update would help)
                  Quicktime is 7.7.6
                  No third party codecs installed
                  Yeah, totally forgot about ensuring the version was up to date.
                  I'll update and test again and report back.  I'm pretty sure my previous install prior to me reinstalling my os/cs6, was on the latest version which would explain why it rendered fine before an not now.  Must have had a lapse in brain activity...should have made sure that was current before posting.
                  Won't be able to try and render again till later so I'll post the results.
                  Thanks for the feedback.
                  • 6. Re: Weird audio issue going on with a MOV file used in project
                    No problem. Hope the update helps!
                    • 7. Re: Weird audio issue going on with a MOV file used in project
                      No joy.  Current AE version is 11.0.4.2.
                      Again, the original footage audio is perfectly fine.  Plays back like it should.  It's almost like AE his a warped version of the video hiding in some small crevice it's holding on to and has the audio playback all jacked.  Makes no difference in timeline, if I move it to other layers, etc.  The rest of the project/video/audio files playback with no issue.  Just this one particular clip.
                      • 8. Re: Weird audio issue going on with a MOV file used in project
                        Try using the Adobe Media Encoder or QuickTime Pro or whatever you have to transcode that file into something else. Heck, I don't care if you convert it to QuickTime so long as it's using a different codec! Then replace that audio in the project with the new audio.
                        • 9. Re: Weird audio issue going on with a MOV file used in project
                          Again, the original footage audio is perfectly fine.  Plays back like it should from within any player (QT Player, Windows media player, VLC).  It's almost like AE his a warped version of the video hiding in some small crevice it's holding on to and has the audio playback all jacked.  Makes no difference in timeline, if I move it to other layers, etc.  The rest of the project/video/audio files playback with no issue.  Just this one particular clip.
                          As another troubleshooting step.  Created a brand new comp.  imported just that single clip.  set the preview area to the problematic time of where the issue occurs.  Do a RAM preview.  Still have the weird looping effect.  Happens at the same place/location in the clip.
                          • 10. Re: Weird audio issue going on with a MOV file used in project
                            ok...let me try transcoding it to another format and see what happens and i'll update with results.  Thanks for the help Szalam.
                            • 11. Re: Weird audio issue going on with a MOV file used in project
                              My guess is that there's some conform file somewhere that's screwy. Hopefully, AME doesn't pull from it.
                              If it does, try making a copy of the footage WITH A DIFFERENT NAME IN A DIFFERENT LOCATION and working from that.
                              • 12. Re: Weird audio issue going on with a MOV file used in project
                                So think you are on to something Szalam.  Tried with AME to transcode audio only to MP3 as well as full on video and audio to MP4.  Both files had the loop.  I used super to pull the audio but the default encoder for super on MP3 is LAME.  Transcoded to MP3 and the file from Super plays the audio back correctly.  I'm not fairly with the inner workings of the Adobe applications so I don't know where  AE/AME are pulling this info from which apparently is contributing to the audio issue.
                                Analysis of the transcoded Super file:
                                [General]
                                Complete name :IMG_0584.MOV.MP3
                                Format :MPEG Audio
                                File size :7.52 MiB
                                Duration :4mn 6s
                                Overall bit rate mode :Constant
                                Overall bit rate :256 Kbps
                                Album :-/-/-/-
                                Track name :IMG_0584
                                Performer :-/-/-/-
                                Released date :UTC 2013-06- 0T18:36:03-0700
                                Recorded date :2015
                                Writing library :LAME3.99.5
                                Comment :SUPER © v2015.build.64+Recorder (February 13, 2015) by eRightSoft
                                major_brand :qt
                                minor_version :0
                                compatible_brands :qt
                                make-eng :Apple
                                model :iPhone 4
                                model-eng :iPhone 4
                                make :Apple
                                encoder-eng :6.1.3
                                date-eng :2013-06-20T18:36:03-0700
                                [Audio]
                                Format :MPEG Audio
                                Format version :Version 1
                                Format profile :Layer 3
                                Mode :Joint stereo
                                Mode extension :MS Stereo
                                Duration :4mn 6s
                                Bit rate mode :Constant
                                Bit rate :256 Kbps
                                Channel(s) :2 channels
                                Sampling rate :44.1 KHz
                                Compression mode :Lossy
                                Stream size :7.52 MiB (100%)
                                • 13. Re: Weird audio issue going on with a MOV file used in project
                                  More tidbits to add to the scenario.
                                  I add the newly transcoded MP3 to the project and timeline and of course it plays through just fine.  I did notice that when I setup the original MOV file, I increased the Audio level to +12dB.  I twirled open the Waveform on the original MOV and the waveform is blank/empty...nothing is showing but gray background.  I twirl open the new MP3 and the wave form is displayed as expected.
