0 Replies Latest reply on Feb 19, 2015 11:09 PM by bastieneichenberger
    check missing font do not work
    bastieneichenberger Level 1
      Hi all,
      I have some troubles to check if a font is correcty installed. I'm writting a script who use the property character.appliedFont.location.
      1) I would like to check if the fonts in the document are correcty installed (The fonts are installed in the document only -> a folder Document fonts with a package).
      - But if I check each font in the document -> every font is installed
      - Then if I would like to use my property from a textframe object I figure it out that the font isn't installed
      I do not understand why the result of font.status is different when I called it from a textframe?
      if (document === undefined) {
         var document = app.activeDocument;
      var fonts = document.fonts.everyItem().getElements();
      for(var i = 0; i < fonts.length; i++){
         if(fonts[i].status !== FontStatus.INSTALLED) {
         //return true;
         alert('no font are uninstalled');
      var textframes = document.pages[0].textFrames;
       * @todo ask why this function do not work!!!
      for (var i = 0; i < textframes.length; i++) {
         if (textframes[i].characters[0].appliedFont.status !== FontStatus.INSTALLED) {
         alert('every textframe font are unavailable');
      return false;
      I advance, thank you for the reply
      Best regards.
