5 Replies Latest reply on Feb 23, 2015 12:21 PM by bregent
    Item cannot be found in the collection corresponding to the requested name or ordinal.
    cmd_jonathan Level 1
      I am using Dreamweavers User Authentication tool, and all seems to be working except when I press the 'Submit' button I get the following error;
      ADODB.Fields error '800a0cc1'
      /coding/test_login.asp, line 35
      As far as I can tell the user login works, as I can assess the restricted page, if I manually type in the URL.
      My code is listed below;
      <!--#include file="Connections/Conn_PSCRM_Demo.asp" -->
      ' *** Validate request to log in to this site.
      MM_LoginAction = Request.ServerVariables("URL")
      If Request.QueryString <> "" Then MM_LoginAction = MM_LoginAction + "?" + Server.HTMLEncode(Request.QueryString)
      MM_valUsername = CStr(Request.Form("usercode"))
      If MM_valUsername <> "" Then
        Dim MM_fldUserAuthorization
        Dim MM_redirectLoginSuccess
        Dim MM_redirectLoginFailed
        Dim MM_loginSQL
        Dim MM_rsUser
        Dim MM_rsUser_cmd
        MM_fldUserAuthorization = """group"""
        MM_redirectLoginSuccess = "yes.asp"
        MM_redirectLoginFailed = "no_access.asp"
        MM_loginSQL = "SELECT usercode, epros_password"
        If MM_fldUserAuthorization <> "" Then MM_loginSQL = MM_loginSQL & "," & MM_fldUserAuthorization
        MM_loginSQL = MM_loginSQL & " FROM DBA.[user] WHERE usercode = ? AND epros_password = ?"
        Set MM_rsUser_cmd = Server.CreateObject ("ADODB.Command")
        MM_rsUser_cmd.ActiveConnection = MM_Conn_PSCRM_Demo_STRING
        MM_rsUser_cmd.CommandText = MM_loginSQL
        MM_rsUser_cmd.Parameters.Append MM_rsUser_cmd.CreateParameter("param1", 200, 1, 255, MM_valUsername) ' adVarChar
        MM_rsUser_cmd.Parameters.Append MM_rsUser_cmd.CreateParameter("param2", 200, 1, 255, Request.Form("password")) ' adVarChar
        MM_rsUser_cmd.Prepared = true
        Set MM_rsUser = MM_rsUser_cmd.Execute
        If Not MM_rsUser.EOF Or Not MM_rsUser.BOF Then
          ' username and password match - this is a valid user
          Session("MM_Username") = MM_valUsername
          If (MM_fldUserAuthorization <> "") Then
            Session("MM_UserAuthorization") = CStr(MM_rsUser.Fields.Item(MM_fldUserAuthorization).Value)
            Session("MM_UserAuthorization") = ""
          End If
          if CStr(Request.QueryString("accessdenied")) <> "" And true Then
            MM_redirectLoginSuccess = Request.QueryString("accessdenied")
          End If
        End If
      End If
      <!doctype html>
      <meta charset="utf-8">
      <title>Untitled Document</title>
      <form action="<%=MM_LoginAction%>" method="POST" name="logon">
      <input name="usercode" type="text"><br>
      <input name="password" type="text">
      <input type="submit" name="Submit" id="Submit" value="Submit">
      Any help greatly accepted.
