1 Reply Latest reply on Feb 20, 2015 3:06 PM by Per Berntsen
    HELP!!! I need to edit my background image.
    jratch94
      I needed to make my spreads wider so that they will print out right.  I did that, but the background images do not grow wit the spread.  How can I edit my background image to fit the sheet?
        • 1. Re: HELP!!! I need to edit my background image.
          Per Berntsen Adobe Community Professional
          You can scale the image in ID, but the resolution will become lower. The resulting quality may or may not be suffient for your needs.
          Check the effective ppi in the Links panel after scaling - it should ideally be 300 for standard commercial printing.
          To proportionally scale the image, hold down Ctrl + Shift with the selection tool, and drag from a corner.
          Alternatively, start over in Photoshop with a high resolution image, save a copy with the required dimensions at 300 ppi.
