18 Replies Latest reply on Jul 12, 2006 7:28 AM by plaing
    Fatal Exception
    kbrimgordon
      Hello, I am using Dreamweaver MX Windows, and in the past week I am getting an error that shuts me down when I: 1: try to change the name of a file from the Dreamweaver site panel (you know, the "geneology tree" thingie on the right side window. I'm not sure of the correct nomenclature to use) or: 2: when I try to open the assets panel.
      When I do either one of these things, it immediately gives me an error that says: "Dreamweaver encountered a fatal exception. Dreamweaver will now terminate."
      Any ideas of what I can do to fix this? I'm hoping I don't have to re-install my software. If that IS the answer, I need to know how to save all my site information so I don't have to manually add all my sites back in. Hopefully that is possible...
      Kbrimgordon
        • 1. Re: Fatal Exception
          Level 7
          http://mm-exporter.joexx.de
          This will take care of your site definition backup problem.
          Which version of DMX are you using? 6.0 or 6.1?
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "kbrimgordon" <webforumsuser@macromedia.com> wrote in message
          news:e81hor$m2k$1@forums.macromedia.com...
          > getting an
          > the
          > right
          > I try
          > that
          > terminate."
          > re-install
          > Hopefully
          > that is possible...
          > Thanks,
          > Kbrimgordon
          • 2. Re: Fatal Exception
            kbrimgordon Level 1
            I am using version 6.0.
            I just installed MM Exporter, and opened it. What do I do now? I'm not much of a geek I'm afraid.
            -Karen
            • 3. Re: Fatal Exception
              Level 7
              You follow the directions in the Exporter. It will export your site
              definitions, FTP info, and other DW info in one pass.
              Also, you must update your DMX6.0 to DMX6.1 at your earliest opportunity -
              there were quite a few bugs in 6.0.
              news:e81p8f$12i$1@forums.macromedia.com...
              > -Karen
              • 4. Re: Fatal Exception
                kbrimgordon Level 1
                OK, I did a full backup, now what do I do with it? I told you, I am really not a techie... I feel a bit lost.
                Karen
                • 5. Re: Fatal Exception
                  kbrimgordon Level 1
                  I have been trying to find the upgrade for DMX6.0 to 6.1, with no luck. Can you point me in the right direction? All I can find is the upgrade to 8.
                  Karen
                  • 6. Re: Fatal Exception
                    Level 7
                    You save it somewhere safe - on your hard drive, a CD, a thumb-drive, a
                    <shudder> floppy, wherever. When you need it, it'll be there.
                    news:e824v8$d6q$1@forums.macromedia.com...
                    > Karen
                    • 7. Re: Fatal Exception
                      Level 7
                      It's here -
                      http://www.adobe.com/support/dreamweaver/downloads_updaters.html#dwmx
                      news:e825ek$dnd$1@forums.macromedia.com...
                      > Karen
                      • 8. Re: Fatal Exception
                        kbrimgordon Level 1
                        Man, you are really making me grovel for this information, Murray. I have of course already saved it somewhere safe... but I have no idea how that helps me fix my problem. Could you throw me a bone here?
                        • 9. Re: Fatal Exception
                          Level 7
                          Sorry - I don't know what you mean. Before trying to troubleshoot your
                          problem, I want to be sure you are on a stable platform. DMX was not that.
                          Please use the link I gave you to update your DMX from 6.0 to 6.1.
                          In other words, I don't want to spend time troubleshooting something that
                          turns out to be a DMX 6.0 problem, you know?
                          Or am I misunderstanding what you are asking?
                          news:e83emi$3jn$1@forums.macromedia.com...
                          > I
                          > that
                          • 10. Re: Fatal Exception
                            kbrimgordon Level 1
                            OK, now I understand more where you are going. I already upgraded to 6.1. I'm guessing that might have taken care of the glichy errors, but now I have no sites defined. I'm assuming that's what I'll use the backup for that I exported with MM-exporter? Can you walk me through how to get the stuff I exported back into the newly upgraded DW? Thanks, Kbrimgordon
                            • 11. Re: Fatal Exception
                              Level 7
                              Run the exporter and IMPORT the sites.
                              news:e859gh$aju$1@forums.macromedia.com...
                              > I'm
                              > no
                              > exported
                              > back
                              • 12. Re: Fatal Exception
                                kbrimgordon Level 1
                                Sould I include the configuration folder?
                                • 13. Re: Fatal Exception
                                  kbrimgordon Level 1
                                  I got impatient, needing to work, so rather than wait for your answer I went ahead and imported everything, including the configuration folderl. I've restarted everything, and my sites aren't showing up in Dreamweaver. Did I screw something up? What do I do next?
                                  • 14. Re: Fatal Exception
                                    kbrimgordon Level 1
                                    OK, the holiday is over and I need to get back to work. I never got an answer from my last two questions... basically, I tried to import my site definitions, and nothing happened. I have a dozen sites that I REALLY don't want to have to totally re-define, since I probably don't even have all the passwords, etc stored anywhere else. HELP!!!
                                    • 15. Re: Fatal Exception
                                      Level 7
                                      What do you mean nothing happened? How did you export the site definitions?
                                      news:e8idiu$em4$1@forums.macromedia.com...
                                      > got an
                                      > don't
                                      > the
                                      • 16. Re: Fatal Exception
                                        kbrimgordon Level 1
                                        I did a "full DW backup" from MM-Exporter, which is saved on my hard drive. Then I upgraded to 6.1, then I opened MM-Exporter and clicked on the Import tab, and clicked the check-box for DW-MX, then I checked the boxes "Resore Settings", and "Restore Configuration Folder". then clicked "Import". Then after about 1 second it said it was finished. I restarted my computer then opened Dreamweaver, and there are no sites there. I have tried to figure out if there was another way to import them , but with no luck. Can you help?
                                        • 17. Re: Fatal Exception
                                          Level 7
                                          The steps you outline should have restored the sites. I have no idea what
                                          failed. I'm sure it's not the exporter, though....
                                          news:e8k5ct$pa9$1@forums.macromedia.com...
                                          > Import
                                          > out if
                                          • 18. Re: Fatal Exception
                                            plaing
                                            Murray I love you from afar -- although the person originally asking the question seems to be still having problems, you solved mine!!! Thank you!!!
