5 Replies Latest reply on Feb 21, 2015 11:32 AM by A.T. Romano
    Issues burning compatible Blu-rays
    morrisst21168409
      I had some complaints that some of the Blu-rays which I recently produced in 1080i were not working on some Blu-ray players.  In researching the issue I learned that many Blu-ray players require an AACS Folder in order to function.  However, the Blu-rays produced by Premiere Elements 13 do not have that folder.  Of course, firmware upgrades may fix the problem on the players, but one can't expect their customers to do that in many cases.  Nor should they.  Then I learn that one can burn an ISO to get the folder onto the disk.  Of course when I try it, I find that it doesn't work on files bigger than 1.3 gigs.  This is a huge problem and I have a job to get out.  Is there a solution?  This was a low budget job, done to line up some large jobs in May and June.  This is the fourth generation of Premiere Elements and there is no reason there should compatibility issues of this sort.  Please restore my faith in Adobe, I am in the process of likely converting to Lightroom an upgrading to full Photoshop from Elements, however at the moment I am very disappointed because I feel this issue is intentional.
        • 1. Re: Issues burning compatible Blu-rays
          A.T. Romano Level 7
          morrisst
          You make a valid point about the Premiere Elements 13 and its unresolved ISO Image file size issue which has not been addressed by Adobe even in its recently released 13.1 Update. Lots of avenues for you to pursue in evaluating your customer comments. I could see your rationale in hunting for the Blu-ray burn to which includes the AACS Folder only if you could support the lack of it being the cause of customer playback issues.
          Have you done the quick test where you have a Timeline that will give you a Blu-ray .iso file end product of less than 1 GB.
          Then doing the comparison
          Publish+Share
          Disc
          Blu-ray
          Disc, with the preset you have been using
          with
          Publish+Share
          Disc
          Blu-ray
          ISO Image (25 GB)
          with the same preset as in burn to disc
          then take the .iso to Blu-ray disc format on Blu-ray disc with ImgBurn?
          Does the .iso route giving player playback versus burn to route which does not give player playback?
          I am working on a workaround. Will let you know shortly if it was a great workaround or a dud.
          To be continued.
          ATR
          • 2. Re: Issues burning compatible Blu-rays
            morrisst21168409 Level 1
            AT,
            Thanks for the response.  This is a huge problem for me. I have a expected $10,000 + job that could be jeopardized as result of this issue, on top of the fact that all of my business is developed by word of mouth.
            Basically, I have been doing professional photography for a couple years now.  Last year, I discovered that I could use Ninja 2s with SLRs and get extremely high quality video from and SLR.  So, I have been using SLRs to do dance videos.  I did not have a back ground in video work, so I chose Premiere Elements because of the learning curve and the fact that the built in menus work great for what I am doing.  It was my intention to move up to Premiere as my skills developed and my wallet fattened. After all, good camera equipment is very expensive, and I have spent a fortune over the past two years.
            Now back to the subject.  The Blu-ray that I am trying to correctly burn is about 11 gigs.  The blu-rays worked in all three of the blu-ray devices that I own, but seem to fail in about half of the players that my customers own. However, my oldest player did require a firmware update before it would play.
            I am using a Pioneer BDR-209D with up to date firmware, I attempted to create the disks from the ISO using both Burnaware Premium and Power 2 Go.  The disk that I am using are Verbatim and not the LTHs which have their own compatibility issues.  The disk I burned were unreadable by all three of my blu-ray devices
            At the moment, I suspect that my only option is to redo the project using a professional grade program unless you can come up with a fix for this issue
            • 3. Re: Issues burning compatible Blu-rays
              A.T. Romano Level 7
              morrisst
              Here is the plan. See if it works for you.
              On the computer desktop create a new empty folder. Name the folder AACC. In the AACC Folder create another new empty folder, and name the folder DUPLICATE. Close out of there.
              In Premiere Elements, do a regular
              Publish+Share
              Disc
              Blu-ray
              disc with your usual preset for this choice. Keep away from the ISO Image (25 or 50 GB) choices.
              After the burn to disc is complete in Premiere Elements, open the Blu-ray disc to explore its contents. Copy its
              BDMV Folder and paste it to the computer desktop.
              Now on the computer desktop, you have your homemade AACC Folder and the BDMV Folder from the Premiere Elements burn to Blu-ray (disc).
              Open ImgBurn, do not use File Menu/ to import the AACC and BDMV Folders from the desktop. Instead, drag each into the blank area underneath
              were it says Source. Hit the Build button at the bottom of that area and follow the instructions. You should end up with a Blu-ray disc with more than 1 GB content and with
              AACC Folder
              BDMV Folder
              CERTIFICATE Folder
              This hybrid works on at least my computer's Blu-ray player.
              Please let us know if that works for you.
              Best wishes
              ATR
              • 4. Re: Issues burning compatible Blu-rays
                Do I need to copy over the Certificate folder as well, or is it automatically created during the burn process?  Another big question is will your blu-ray player not otherwise play the disk if the AACC folder is missing.  All of my clients who are are experiencing this issue are literally a 100 mile round trip away.  Oh well, ones got to do what ones got to do.
                Hope this works.  Thanks for the quick response.
                • 5. Re: Issues burning compatible Blu-rays
                  A.T. Romano Level 7
                  morrisst
                  Thanks for the reply.
                  Do not copy the CERTIFICATE Folder from the Premiere Elements burn to Blu-ray disc, only its BDMV Folder in the plan described above.
                  ImgBurn should generate the CERTIFICATE Folder....to be sure....
                  Tools Menu
                  Settings
                  Build Tab
                  Page 2
                  and look for the Blu-ray options and have a check mark next to them
                  ....Create BDMV Folders
                  ....Create CERTIFICATE Folder
                  My computer Blu-ray player plays
                  a. Premiere Elements burn to Blu-ray disc after burn to in Premiere Elements
                  b. The Premiere Elements BDMV + CERTIFICATE Folders with or without the AACC Folder
                  The following may be of interest
                  ATR Premiere Elements Troubleshooting: PE 13: Blu-ray ISO Image and AACS Folder
                  The AACC Folder may not be the answer. If not, is there anyway you can compile
                  player data for those reporting problems regarding playback of these discs?
                  We will be watching for further developments as your schedule permits.
                  Best wishes
                  ATR
