ok so frame 1 in the timeline/layer, I have this code
stop();
var btn1:MCButton = new MCButton();
btn1.x = 1048;
btn1.y = 300;
btn1.label_txt.text = "play";
addChild(btn1);
btn1.gotoAndStop(10);
var btn2:MCButton = new MCButton();
btn2.x = 1048;
btn2.y = 380;
btn2.label_txt.text = "help";
addChild(btn2);
var btn3:MCButton = new MCButton();
btn3.x = 1048;
btn3.y = 460;
btn3.label_txt.text = "highscore";
addChild(btn3);
and now I have a MCButton class (.as)
package {
import flash.display.MovieClip;
import flash.events.MouseEvent;
public class MCButton extends MovieClip {
public function MCButton() {
// constructor code#
stop();
this.buttonMode = true; //makes movie class into btn
this.addEventListener(MouseEvent.MOUSE_OVER, hover);//listen for a mouse hover event
this.addEventListener(MouseEvent.MOUSE_DOWN, down);//listen for a mouse down event
private function hover(e:MouseEvent):void {
this.removeEventListener(MouseEvent.MOUSE_OVER, hover);
this.addEventListener(MouseEvent.MOUSE_OUT, out);
this.gotoAndStop(2);
private function out(e:MouseEvent):void {
this.removeEventListener(MouseEvent.MOUSE_OUT, out);
this.gotoAndStop(1);
private function down(e:MouseEvent):void {
this.gotoAndStop(3);
ok so I want btn1 (which is in my layers) to go frame 10, where I have another menu for "easy" "medium" "hard", I have put btn1.gotoAndStop(10); but that doesnt seem to work, so I'm really confused on what im doing wrong.
Please help me,
Thanks.
you can`t remove sth. that has not been created:
removeChild(btn6);
var btn6:MCButton = new MCButton();
you try to remove btn6-9 before they have been created
I understand why you want to do it, but you have to make sure that the remove part is left out the first time.
You can do it by making sure that the button you try to remove is actually there
Change every line that removes sth. to:
if(btn6!=null){
removeChild(btn6);
if(btn7!=null){
removeChild(btn7);
etc.
Caveat:
Trying to setup a Navigation like
...Copy link to clipboard
You have btn1 already on stage or what? Not sure what you're saying here. You can't have it already on stage and then instantiate it as per the above. And you can remove every reference to this in your button class code. You're in 'this', there's no reason to reference it like that.
sorry for the bad english, I have made a actionscript layer (frame1) in my timeline and I put this code inside it
btn1.x = 1048;
btn1.y = 300;
addChild(btn1);
because I have a MCButton class already, I'm trying to make a OOP Menu, but thats where im getting stuck because I dont know how to make it so when the user clicks that button it goes to frame 10, where I have a second set of buttons called "easy", "medium", "hard"
You want the timeline inside of btn1 to go to frame 10? That is what the code is trying to tell it to do. If so, using that button will cause it to go to frames 1,2, or 3 depending on how you interact with it.
on the timeline, my action script layer (1), i have code to generate buttons from my button class.
I want it, so when a user clicks on this btn1 it will go to frame 10 where I have a second set of buttons called "easy", "medium", "hard"
i hope this clears up confusion, looking forward to your replies.
ThaNKS A lot
You created the buttons so they are still there even if you move to another point of the timeline.
If you created the buttons with code you have either to get rid of them like so:
function playMenu(e:MouseEvent):void{
gotoAndStop(10);
removeChild(btn2);
removeChild(btn5);
or better:
just change all the labels to the desired ones and don`t jump to frame 10 at all:
btn1.label_txt.tetx = ""easy";
btn2.label_txt.text = "medium";
btn3.label_txt.text = "hard";
btn5.label_txt.text = "main menu";
// hide the buttons not needed
btn4.visible = false;
thank you, doing the removeChild method worked,
but I now this error and im not sure why?
TypeError: Error #2007: Parameter child must be non-null.
at flash.display::DisplayObjectContainer/removeChild()
at hypernova/frame1()[hypernova::frame1:40]
This is my code for AS Layer frame 1
stop();
btn1.x = 1048;
btn1.y = 300;
addChild(btn1);
btn2.x = 1048;
btn2.y = 380;
addChild(btn2);
btn3.x = 1048;
btn3.y = 460;
addChild(btn3);
var btn4:MCButton = new MCButton();
btn4.x = 1048;
btn4.y = 540;
btn4.label_txt.text = "awards";
addChild(btn4);
var btn5:MCButton = new MCButton();
btn5.x = 1048;
btn5.y = 620;
btn5.label_txt.text = "exit";
addChild(btn5);
btn1.addEventListener(MouseEvent.CLICK, goplayMenu);
function goplayMenu (e:MouseEvent):void{
trace("play menu!");
gotoAndStop(10);
removeChild(btn6);
removeChild(btn7);
removeChild(btn8);
removeChild(btn9);
and frame 10
stop();
removeChild(btn1);
removeChild(btn2);
removeChild(btn3);
removeChild(btn4);
removeChild(btn5);
btn6.x = 1048;
btn6.y = 300;
btn6.label_txt.text = "easy";
addChild(btn6);
var btn7:MCButton = new MCButton();
btn7.x = 1048;
btn7.y = 380;
btn7.label_txt.text = "med";
addChild(btn7);
var btn8:MCButton = new MCButton();
btn8.x = 1048;
btn8.y = 460;
btn8.label_txt.text = "hard";
addChild(btn8);
var btn9:MCButton = new MCButton();
btn9.x = 1048;
btn9.y = 540;
btn9.label_txt.text = "main menu";
addChild(btn9);
btn9.addEventListener(MouseEvent.CLICK, mainMenu);
function mainMenu (e:MouseEvent):void{
trace("back to menu");
gotoAndStop(1);
when I go back to main menu, I didnt want the playmenu to conflict with the main menu which is why I removedChild for everything
removeChild(btn6);
if(btn6!=null){
removeChild(btn6);
if(btn7!=null){
removeChild(btn7);
etc.
Caveat:
Trying to setup a Navigation like this can not be considered good OOP Practice.
That`s why I said you should target a solution that does not rely on timeline navigation.
