9 Replies Latest reply on Sep 8, 2017 3:47 PM by Obi-wan Kenobi
    Text variables (meta data) "overlaps" in ToC
    adb11107255
      I'm trying to create a list of figures with the ToC function how it is officially described by Adobe (Numbered Lists — Part III Figure Captions).
      Now I have multiple metadata entries in each caption via text variables in the same paragraph (in order for the ToC to recognize all of that text).
      The problem is when creating a ToC the caption text (which is generated by the text variables) is "overlapping"/mixing and thus useless.
      For example:
      caption: "Fig.1 - <metadata description> <metadata source>" is shown correctly as: "Fig1. - description (c)source"
      When creating a ToC following happens inside the generated ToC:
      "Fig.1 - d(c)sourceon" instead of "Fig1. - description (c)source".
      As you can see the variables text is "overlapped" and mixed into each other
      The only solution I have found so far is converting the text variables to static text (and thus losing the dynamic update functionality of text variables).
