• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
argument error #2068: Invalid sound
Community Beginner ,
Feb 22, 2015 Feb 22, 2015
I'm trying to use the static variables and methods for the first time.
So I took the code, I had previously on an upper level component, down to the related class file.
Its all working fine, but the sound does not want to play.
Gives the error: Invalid sound. The row is marked bold.
What is causing that error?
Many thanks in advance!
private static var numberForFlowerSound: uint = 0;
private static var flowerSound01: BellLoop01Multitrack = new BellLoop01Multitrack();
private static var flowerSound02: BellLoop02Multitrack = new BellLoop02Multitrack();
private static var flowerSound03: BellLoop03Multitrack = new BellLoop03Multitrack();
private static var flowerSound04: BellLoop04Multitrack = new BellLoop04Multitrack();
private static function countForFlowersSound(): void
            numberForFlowerSound++;
       if (numberForFlowerSound == 1)
          flowerSound01.play();
     else if (numberForFlowerSound == 2)
            flowerSound02.play();
       else if (numberForFlowerSound == 3)
            flowerSound03.play();
       else if (numberForFlowerSound == 4)
            flowerSound04.play();
            numberForFlowerSound = 0;
TOPICS
ActionScript
Views
2.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
what's BellLoop01MultiTrack?
Votes
Translate
Translate
Report
Report
all the BellLoops are mp3 files.
Votes
Translate
Translate
Report
Report
Community Expert ,
Feb 23, 2015 Feb 23, 2015
attach a screenshot of your library that shows the mp3 linkages.
Votes
Translate
Translate
Report
Report
Votes
Translate
Translate
Report
Report
Community Expert ,
that looks ok.
are you calling that 'private' static function from a public static function?
Votes
Translate
Translate
Report
Report
its called from a private function in the same class file.
I could copy the entire code, but its quite long.
When I comment out all four sound related rows, then the code is running as expected.
And it was running as expected, including sound, when it was in other class file and without the static.
But I want to learn coding with static var and methods.
Any ideas why the sound does not want to play?
Votes
Translate
Translate
Report
Report
Community Expert ,
well, is there a public static function the indirectly calls that private static function?
if not, how do you get that to execute?
Votes
Translate
Translate
Report
Report
Feb 24, 2015 Feb 24, 2015
I made simplified version of the class file, left out all animation part.
When the sound related rows (marked bold) are commented out and I click on different instances of that class on stage, I can see the expected trace statement. And it is counting up until four and then starting again from 0. As expected.
Whit the sound rows uncommented I still get the same error message.
package BoyWithScooter
                import flash.display.*;
                import flash.events.*;
                import flash.media.Sound;
                public class Flowers extends MovieClip
                               public function Flowers()
                                               addedToStage_Flowers();
                               private function addedToStage_Flowers(): void
                                               this.addEventListener(MouseEvent.CLICK, flower);
                               private function flower(event: MouseEvent): void
                                               Flowers.countForFlowersSound();
                                                               trace("numberForFlowerSound is " + numberForFlowerSound);
Votes
Translate
Translate
Report
Report
Community Expert ,
i don't know why you're seeing that error message, but your code makes no sense.  that's not the way you would use a static mehtod/variable.
just make them private and your code will work.
typically you would create a public static method.  then you can execute it from any class in your package without needing to create a class instance.
Votes
Translate
Translate
Report
Report
Thanks kglad.
I reviewed the code and found out that I was overdoing with the static.
It is enough when only the var numberForFlowerSound is static - keeps track for all instances of that class on the stage, not one by one.
And the function and the sounds do not need to be static.
Got it working as I needed it.
Votes
Translate
Translate
Report
Report
Mar 03, 2015 Mar 03, 2015
kglad, could you please mark your last answer as helpful.
Cant consider it as completely correct answer to my question, but it definitely helped me to solve my issue.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
sure.
but your solution obviates the only reason to use a static variables: so you can use a public static method.
here's an excerpt from a singleton class (only one instance can be created), for example:
package com.kglad {
    public class Data {
        private static var data:Data;
        private static var allowInstantiation:Boolean;
    public static function getInstance():Data {
            if (data == null) {
                allowInstantiation=true;
                data = new Data();
                allowInstantiation=false;
            return data;
        public function Data():void {
            if (! allowInstantiation) {
                throw new Error("Error: Instantiation failed: Use data.getInstance() instead of new.");
        public static function getWordAF(level:int):Array{
            return data["wordsG"+level];  // these variables are defined in the Data class and are available everywhere in com.kglad by using, var d:Data=Data.getInstance(); d.getWordAF(3);
Votes
Translate
Translate
Report
Report
