1 Reply Latest reply on Feb 23, 2015 8:02 AM by A.T. Romano
    shake-stabilizer difficulty
    jonas013 Level 1
      Hi !
      I'm trying to use shake-stabilizer feature in Premiere 13.1 for the first time.
      Everything seems to work fine, but when I publish the final movie the result is very poor as you can see on this screenshot.
      I tried different output format (HD and DVD; 24, 25 and 30 i/s; p and i); I tried also several palyer (VMC, MS, Quicktime, Premier); the result is always the same.
      I must say tha the original video is very shaky.
      Thank you for your help.
      md
        • 1. Re: shake-stabilizer difficulty
          A.T. Romano Level 7
          jonas013
          After you have applied video stabilization to your Timeline video, what does the stabilized video (which has been Timeline rendered) look like in the Edit area monitor?
          Is your issue confined to the quality of the export?
          If so, please give more information
          1. Properties of your source media - especially frame rate interlaced or progressive, and, if interlaced, upper or lower field first.
          2. Project Settings (See Edit Menu/Project Settings/General and readings for Editing Mode, Timebase, Frame Size, and Pixel Aspect Ratio - even if they look grayed out)
          We can discuss the export setting next depending on the above.
          Please do not hesitate to ask questions or to ask for clarification.
          Thank you.
          ATR
