6 Replies Latest reply on Feb 26, 2015 11:11 AM by info@herre.at
    Virtual copies are not synchronized in a second Lightroom catalogue although metadata are written in XMP and synchronization with metadata was selected
    info@herre.at
      Dear community,
      I operate one Mac with Lightroom 5.7 that is configured to store all metadata in xmp files. The Lightroom catalogue is stored locally on the Mac and only contains references to the images and their xmp files that are stored on a network device. There is another Mac with the same configuration having a separate local Lightroom catalogue and access to the same images on the network device.
      At a starting point, both Lightroom catalogues are identical - they refer to the same images on the network device and contain the same metadata.
      When I update image properties on the first Mac, these changes are reflected in the xmp file. After using the option "synchronize" with activated "metadata synchronization" on the second Mac, the modified image properties are visible on the second Mac. This is fine.
      However, when I create a virtual copy on the first Mac, I realize that the corresponding xmp file gets updated. However, even after synchronization, the virtual copy is not visible on the second Mac. I may modify image properties of the original image and get these modifications replicated to the second Mac, but the virtual copies remain on the first Mac.
      What needs to be done that also virtual copies get synchronized?
      Thank you very mich for your support.
      Best regards,
      Peter
