1 Reply Latest reply on Mar 29, 2015 9:57 PM by Anubha Goel
    Custom checkbox style
    JButurff
      Is there a way to create a custom style for a checkbox?  Basically, I want to put a letter inside the checkbox (ie, Y/N/M/C), and I would like to circle the letter if the user selects it.
      Any time I add text, it seems to go behind the checkbox.  So I figure I could create a custom image/bitmap for the on/off of the checkbox, but is there a way to use that?  Some other better way to do this?
      Any help greatly appreciated!
        • 1. Re: Custom checkbox style
          Anubha Goel Adobe Employee
          Hey JButurff,
          As per my knowledge, using Acrobat, you can either change the line style of check boxes under "Properties > Appearance > Line Style"
          or you can also choose to change the shape of marker inside the check box under "Properties > Options > Check Box Style"
          Whatever letter you put inside the check box will be hidden once you close form editing.
          Regards,
          Anubha
