8 Replies Latest reply on Oct 13, 2017 7:58 AM by Sudha K
    Move text frame to a layer
    nellbern
      Need batch ID docs. & get all instances where the paragraph  style "Codes" was applied, create a new layer "PR" & move text frames containing that paragraph  style to a layer "PR". This what I have so far. Any help is appreciated. ================
      set source_folder to choose folder with prompt "Select folder containing Indesign Documents to move codes to a diffrent layer"
      tell application "Finder" to set theFiles to files of source_folder whose name extension is "indd"
      if (count of theFiles) is 0 then
         display dialog "No InDesign files to process" buttons "Cancel" default button "Cancel" with icon 0 giving up after 6
         return
      end if
      end
      --loop the selected folder
      repeat with oneFile in theFiles
         tell application "Adobe InDesign CS4"
             --ignore dialogs
             set user interaction level of script preferences to never interact
             activate
             set myDocument to open (oneFile as alias)
             tell myDocument
                 --find pstyle
                 set myPstyle to paragraph style "CODES"
                 -- if the page is a spread
                 set x to properties of spread 1
                 set LayerName to "PR"
                 try
                     set myLayer to layer LayerName
                     set the properties of myLayer to {locked:false}
                 on error
                     --create layer if does not exist
                     set myLayer to make layer with properties {name:LayerName, layer color:red, visible:true}
                 end try
                 --get all instances where paragraph style CODES was applied only & move text frames to a PR layer
                 set myObjects to (every text frame whose applied paragraph style is myPstyle and item layer is myLayer)
                 move (every text frame whose applied paragraph style is myPstyle) to layer "PR"
                 close myDocument saving yes
                 display alert "Opening next document..." giving up after 2
                 --put the prefs the way it was
                     set user interaction level of script preferences to interact with all
                 end tell
             end tell --myDoc
         end tell --Indesign
      end repeat
