0 Replies Latest reply on Feb 24, 2015 8:02 PM by Lennos38406912
    Adobe Digital Edition 4.0.3 on Windows 8.1 will only run as Administrator
    Lennos38406912
      When trying to run ADE4.0.3 as standard user on Windows 8.1 nothing happens but I can see it is producing Windows Error Reports when monitoring it with Process Explorer and the Windows Application log shows two events (id 1026 and 1000) in quick succession when I try to launch it. See extracts of the Windows event logs below.
      When I run the application as an Administrator their is no problems and the application launches as expected. It would appear to be some sort of permissions error either in .Net Framework, File system or registry. Please assist.
      Event ID 1026 (None) Source = .NET Runtime
      Application: DigitalEditions.exe
      Framework Version: v4.0.30319
      Description: The process was terminated due to an unhandled exception.
      Exception Info: System.Configuration.ConfigurationErrorsException
      Stack:
         at System.Configuration.ClientSettingsStore.WriteSettings(System.String, Boolean, System.Collections.IDictionary)
         at System.Configuration.LocalFileSettingsProvider.SetPropertyValues(System.Configuration.Set tingsContext, System.Configuration.SettingsPropertyValueCollection)
         at System.Configuration.SettingsBase.SaveCore()
         at System.Configuration.SettingsBase.Save()
         at System.Configuration.ApplicationSettingsBase.Save()
         at DE.ConfigurableWindowSettings.SetValue(System.String, System.Object)
         at DE.MainWindow.SelectTileView()
         at DE.MainWindow..ctor()
         at DE.App.OnStartup(System.Windows.StartupEventArgs)
         at System.Windows.Application.<.ctor>b__1(System.Object)
         at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
         at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
         at System.Windows.Threading.DispatcherOperation.InvokeImpl()
         at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(System.Object)
         at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
         at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
         at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
         at System.Windows.Threading.DispatcherOperation.Invoke()
         at System.Windows.Threading.Dispatcher.ProcessQueue()
         at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
         at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
         at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
         at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherP riority, System.TimeSpan, System.Delegate, System.Object, Int32)
         at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
         at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
         at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFram e)
         at System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame)
         at System.Windows.Threading.Dispatcher.Run()
         at System.Windows.Application.RunDispatcher(System.Object)
         at System.Windows.Application.RunInternal(System.Windows.Window)
         at System.Windows.Application.Run(System.Windows.Window)
         at DE.App.Main()
      Event ID 1000 (100)  Source = Application Error
      Faulting application name: DigitalEditions.exe, version: 4.0.3.0, time stamp: 0x54db41a1
      Faulting module name: KERNELBASE.dll, version: 6.3.9600.17415, time stamp: 0x54504ade
      Exception code: 0xe0434352
      Fault offset: 0x00014598
      Faulting process ID: 0x166c
      Faulting application start time: 0x01d050a2de2bc8ed
      Faulting application path: C:\Program Files (x86)\Adobe\Adobe Digital Editions 4.0\DigitalEditions.exe
      Faulting module path: C:\WINDOWS\SYSTEM32\KERNELBASE.dll
      Report ID: 228c3a9f-bc96-11e4-8120-000129006bc4
      Faulting package full name:
      Faulting package-relative application ID:
