7 Replies Latest reply on Feb 25, 2015 5:41 PM by A.T. Romano
    go pro 2704*1520
    guyl88898706
      Hi
      Sorry for my english but i will try to explain my problem
      I maked lot of video with go pro 4 black in 2k 48fps for uzed the stabilizer et now i see there is not preconfig the set up in premiere element 13
      I will like to use the shaker stabilizer
      how can i do it
      thx
        • 1. Re: go pro 2704*1520
          Premiere Elements can work with 1920x1080 high-definition video as well as 3840x2160 XAVC video. There is no project setting for natively editing 2704x1520 video, Guy.
          • 2. Re: go pro 2704*1520
            A.T. Romano Level 7
            guyl
            True there is no project preset for 2.7K in Premiere Elements. But you can easily create one from an existing project preset.
            Within the hour, I will be publishing the details of creating a AVCHD 1524p60 project preset which, when used as the project preset for 2.7 K (2704 x 1524p60) video
            should enable you to use the Shake Stabilizer for your 2.7 K (2704 x 1524p60).
            I have done a work through, and it does work.
            If you try it, looking forward to your results with it. I will post the link to the details here as well as in the thread of Sergio who asked this question here last night.
            ATR
            Add On...I see GoPro as 2.7K as 2704 x 1524
            What exactly is 4k cin and 2.7k cin? : gopro
            What is yours...2704 x 1520?
            • 3. Re: go pro 2704*1520
              A.T. Romano Level 7
              guy
              This is the information on how to create your own 2704 x 1524 60p project preset to enable Shake Stabilizer to work with 2.7 K video in Premiere Elements 13/13.1 when this
              project preset is used.
              ATR Premiere Elements Troubleshooting: PE 13/13.1: 2.7 K Video Stabilization With Shake Stabilizer
              Although the steps are described for 2704 x 1524 60p, you can adjust the values pointed to in the how to to match your video properties for 60p video. If you have 30p, next I can tell you
              how to do that also.
              Please let us know if this worked for you. And, please indicate the actual resolution of your 2.7K video 2704 x 1524, 2704 x 1500, or other.
              Thank you.
              ATR
              • 4. Re: go pro 2704*1520
                guyl88898706 Level 1
                thank you for yours answers
                i will check this tomorrow
                thank you again
                • 5. Re: go pro 2704*1520
                  You are a perfect guy
                  that's works i can stabilize in 2.7k now
                  and now i have a new problem i cant usedShake Stabilizer with the remapping time for a slow motion but i think
                  there aren't solution maybe a patch
                  well thank you very much
                  • 6. Re: go pro 2704*1520
                    whsprague Adobe Community Professional
                    This topic made me curious.  It reminded me of the efforts to make PrE 9 work with 1920x1080p60 clips when that was new.  I borrowed a "27K60" clip from a new GoPro Hero 4 Black with the firmware that came out this month.  I tried your directions for modifying a preset.   I had a little trouble understanding the directions.   It would have helped me if change 2 was in two steps.  But, I finally got it.
                    The first time I tried the new Preset, it failed to work.  I checked the clip properties and they were at 1520, not 1524.  I did it over with 1520 and the Shake Stabilizer worked fine.  I put the finished preset file on DropBox if anybody wants it.  I think the owner of the clip would let you use it for testing and can get you a link if you want.
                    Dropbox - AVCHD 1520p60.sqpreset
                    For whatever it might be worth, I don't think GoPro ever bought into the Sony/Panasonic trademarked "AVCHD".  If I were to change the preset again, I would use "GoPro 2.7K60" in the name instead of "AVCHD".
                    Thank you for working this out and writing the instructions.
                    Bill
                    • 7. Re: go pro 2704*1520
                      A.T. Romano Level 7
                      guyl
                      Thanks for the follow up with the good news that the suggestion worked for you.
                      I followed up on your comment
                      and now i have a new problem i cant used Shake Stabilizer with the remapping time for a slow motion
                      Thanks for that question. I did not realize before the Time Remapping does not work on a clip that has been video stabilized with
                      the Shake Stabilizer.
                      Applied the Shake Stabilizer successively then tried for the Time Remapping. No go for the Shake Stabilizer video for slow or fast motion with Time Remapping.
                      Red message across the screen: Shake Stabilizer and Time Remapping can't be used on same clip message.
                      I did this with 1080p video to rule out that the newly created for project preset for 2.7K was not involved. It was not.
                      I did another test where I did the Time Mapping first and then the Shake Stabilizer. Same result - same message as when I did Shake Stabilizer first and then Time Remapping.
                      And, if I applied the Shake Stabilizer to the clip and then tried to apply a fast motion effect with Time Stretch, no go.
                      Red nessage across the screen: Shake Stabilizer and Speed can't be used on same clip.
                      Adobe has just updated 13 to 13.1, and I did these studies using Premiere Elements 13/13.1, so I am not expecting
                      any patches on this one soon. Not sure Adobe will or can make this scenario possible.
                      I would have to work through the details, but I am suspecting the way around this might be to Shake Stabilize the clip, export it,
                      import it, and then apply the slow or fast motion effects.
                      You brought up two very interesting matters in your questions. Many thanks.
                      Best wishes
                      ATR
