2 Replies Latest reply on Feb 26, 2015 5:30 AM by machipotHocine
    Refresh dialog window
    machipotHocine Level 1
      I am stuck with a dialog refresh!!!
      I am trying to refresh my dialog in order to switch from one language to another
      any idea?
      Thank you,
      here is my portion of code:
        • 1. Re: Refresh dialog window
          UQg Level 4
          It is impossible to test your code if you post it in a picture.... and impossible to copy/paste to answer...
          The texts are not dynamically refreshed by the single statement $.locale="fr", even if you have used localize({en :"", fr: ""}) everywhere.
          For instance, the myWindow.text, which is localize({en: "Compare two documents", "fr: Comparer deux documents"}), is evaluated upon creation and then it is just a piece of string,
          what it would have been in the other case is completely forgotten.
          You need a function that sets the text for all widgets with a text property, and which can be called over and over when the user clicks one of the language buttons.
          Xavier.
          • 2. Re: Refresh dialog window
            Hi Xavier,
            Sorry, here is my code portion:
            For your info, in line 195 (picture code), when I replace it by $.locale = "fr";
            the dialog is displayed in French language.
            ----- code-------------------
            function ShowDialog() {
            var mySavedDocs = [];
            var mySavedDocNames = [];
            for (var j = 1; j < myDocs.length; j++) {
            if (myDocs[j].saved) {
            if (mySavedDocs.length == 0) OnError(localize({en: "You don't have any saved documents to compare with the active document.", fr: "Aucun document a comparer avec le document actuel"}));;
            var myWindow = new Window("dialog", localize({en: "Compare two documents", fr: "Comparer deux documents"}));
            myWindow.alignChildren = "fill";
            // Properties for group language buttons
            var groupLng = myWindow.add('group',undefined);
            groupLng.orientation = "stack";
            groupLng.alignment = ['right','top'];
            var fButton = groupLng.add('iconbutton',undefined,"C:/Users/Pictures/F.jpg", {style:'toolbutton'});
            fButton.text = "Français";
            //fButton.onClick = lngPreference;
            //myWindow.layout = new AutoLayoutManager(myWindow);
            fButton.onClick = function(){
            fButton.visible = false;
            eButton.visible = true;
            $.locale = "en";
            var eButton = groupLng.add('iconbutton',undefined,"C:/Users/Pictures/E.jpg", {style:'toolbutton'});
            eButton.text = "English";
            //----default button language is english -----
            fButton.visible = true;
            eButton.visible = false;
            //----default language is english -----
            $.locale = "en";
            //eButton.onClick = lngPreference;
            eButton.onClick = function(){
            $.locale = "fr";
            // Properties for groupMain
            var groupMain = myWindow.add('group',undefined);
            // Properties for group left
            var groupLeft = groupMain.add('group',undefined);
            groupLeft.add('image',undefined,"C:/Users/dahmanib/Pictures/compare.jpg");
            groupLeft.orientation = "column";
            groupLeft.alignChildren = "top";
            // Properties for Window1.Panel1.Group1.Image1
            var groupRight = groupMain.add('group',undefined);
            groupRight.orientation = "column";
            groupRight.alignChildren = "top";
            var panelMain = groupRight.add('panel',undefined, localize({en: "- Compare Two Documents -" , fr: "- Comparer deux documents -"}));
            panelMain.alignChildren = "left";
            //panelMain.orientation = "ligne";
            var myGroup1 = panelMain.add("group");
            myGroup1.orientation = "row";
            var myStText1 = panelMain.add("statictext", undefined, myDoc1.name + localize({en: " with ", fr: " avec "}) );
            myStText1.helpTip = app.documents[0].fullName.fsName.replace("/Volumes/", "");
            var myDropdownlist = panelMain.add ("dropdownlist", undefined, mySavedDocNames);
            myDropdownlist.helpTip = mySavedDocs[myDropdownlist.selection.index].fullName.fsName.replace("/Volumes/", "");
            myDropdownlist.onChange = function() {
            var myDropdownlistSelected = myDropdownlist.items[myDropdownlist.selection.index];
