the old BC editor had this nice breadcrumb at the bottom to show all tags, a text is wrapped into. One could simply click the "remove tag" link right to the breadcrumb to get rid of redundant markup (p > p > strong > font > font). Is there any similar function in the new editor, too?
Hi Claudia,
Redundant tags should not be generated by the editor so the need to select and remove such tags should actually go away. For other scenarios where you might need that, unfortunately, we will not have this functionality available in the new editor.
Cristinel
You should not need that on the new one, When everything is finished and tweaked.
Why is that?
Hi Claudia,
Cristinel
By the way: when working in the editor there is no line-break functionality. This is very cumbersome especially when editing forms or long copy. Its hard to handle those horizontal scrollbars. Any trick to avoid lots of line-breaks manually?
Claudia,
As with any editor - Enter - Paragraph, Shift enter - line break. Same for word, notepad... Everything
What Cristinel said is correct, At the moment it is creating blank paragraphs and breaks for no reason as it as a few tweaks etc still to go yet - But when they are addressed its a lot cleaner editor but that is because its handling things better. Paste direct from word into it and look at the code - really clean.
