Hi All,
I'm having a real problem using runtime shared libraries in flash professional. Basically i need to be able to use the same library across multiple swfs so that when items in the library are updated the swfs reflect this without being re-published. So i have created an SWC file and placed it in a local folder. Then in the publish settings in Flash i've added the path to the swc by clicking browse to swc file. If i click on the 'i' icon on the path i can see that the 'merge into code' option is checked by default. This publishes fine. However when i change that option to 'runtime shared library' and insert the path where the swc is located i get:
rsl error!
numComplete 0
numFailed 0
numComplete 0
What am i doing wrong here? its driving me nuts!
Many Thanks
Matt
Have something to add?
