0 Replies Latest reply on Feb 26, 2015 2:51 AM by rajus.singh@adobe
    I am geting following error please help
    rajus.singh@adobe Level 1
      ERROR-
      RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032: Stream Error. URL: http://www.nature.com/principles/webservice/login" errorID=2032]. URL: http://www.nature.com/principles/webservice/login"]
      code-
      operation = new Operation(null, "login");
        operation.url = "login";
        argsArray = new Array("login_id", "login_password", "unique_machine_id");
        operation.argumentNames = argsArray;
        operation.method = "POST";
        operation.serializationFilter = filter;
        operations.push(operation);
        public function login(loginId:String, loginPassword:String, uniqueMachineId:String):AsyncToken
             trace(loginId, loginPassword, uniqueMachineId);
             var _internal_operation:AbstractOperation = _service.getOperation("login");
             var _internal_token:AsyncToken = _internal_operation.send(loginId, loginPassword, uniqueMachineId);
             return _internal_token;
      login service is being called from server that is in java-
      package com.nature.ebook.components.auth
        import com.nature.ebook.data.UserInfo;
        import com.nature.ebook.services.CallStatus;
        import com.nature.ebook.services.IEBookService;
        import com.nature.ebook.services.XMLServiceParser;
        import flash.events.EventDispatcher;
        import flash.events.IEventDispatcher;
        import mx.controls.Alert;
        import mx.rpc.AsyncToken;
        import mx.rpc.Fault;
        [ManagedEvents("authSuccess, authFail")]
        public class AuthCommand extends EventDispatcher
        public function AuthCommand(target:IEventDispatcher=null)
        [Inject]
        public var service:IEBookService;
        [Inject]
        public var auth:AuthModel;
        //  Methods
        * This command dispatches  event AuthenticationEvent.AUTH_FAIL when the service return failt
        * @param fault Fault
        public function error(fault:Fault):void
        trace(fault);
        var e:AuthenticationEvent = new AuthenticationEvent(AuthenticationEvent.AUTH_FAIL, null, null, CallStatus.getServerFaultCall());
        dispatchEvent(e);
        * This command dispatches event when the service return rezult Array
        * @param result Array
        * if cs.success <code>true </code> dispatch AuthenticationEvent.AUTH_SUCCESS
        * if cs.success <code>false</code> dispatch AuthenticationEvent.AUTH_FAIL
        public function result(result:*):void
        if (result)
        var cs:CallStatus = XMLServiceParser.getCallStatus(result);
        if (cs.success)
        var us:UserInfo = XMLServiceParser.getUserInfo(result);
        var e:AuthenticationEvent = new AuthenticationEvent(AuthenticationEvent.AUTH_SUCCESS, us, null, cs);
        dispatchEvent(e);
        else
        e = new AuthenticationEvent(AuthenticationEvent.AUTH_FAIL, null, null, cs);
        dispatchEvent(e);
        public function execute(event:AuthenticationEvent):AsyncToken
        return service.login(event.user.loginId, event.magicWord, event.user.uniqueMachineId);
