Hej!
Kan man ladda ner en testversion flera gånger?
Gjorde det för c:a 6 månader sedan och körde en studiecirkel.
Har fått frågan om jag kan köra den igen men andra personer.
Det handlar om ideell verksamhet i en fotoklubb.
Trial versions can be downloaded multiple times but can only be used once on a system. You need to get a new system in order to run the trial again.
What is the difference between brief education and professional education? Does it somehow take less time to learn the same material unprofessionally? You should purchase the software if you have already evaluated it and found it to be suitable to your needs. Take up a collection in the club and use it to purchase a brief education version.
you can download as many times as you want. but you are limited to, at most, 30 days use on any one computer.
2015-02-27 14:01 skrev kglad:
THANKS FOR A CONCRETE ANSWER!
CAN I DOWNLOAD AN EVALUATION VERSION SEVERAL TIMES? I WANT TO DO IT FOR BRIEF EDUCATION. NOT FOR PROFESSIONAL EDUCATION.
created by kglad in Downloading, Installing, Setting Up - View the full discussion
you're welcome.
