• Global community
    • Language:
      • Deutsch
      • English
      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
Exit
0
Presenter 9 problem while video importing
New Here ,
Feb 27, 2015 Feb 27, 2015
I have a problem with Presenter 9 and I don't know if it is my misunderstanding or I understood something wrong.
I work with videos so I need to import videos/animations with Presenter.
- When I insert a .swf I have no problems and all works properly.
- If I try to insert any other video I canĀ“t (.flv. H.264, MPG.....) As far as I understood, not having Quicktime could be only problematic in case of being necessary a preview. I don't set "preview" and when I try to insert the video it appears always the same fail problem about QuickTime.
Is there no way to insert a video (any format different to .swf animations) without having QuickTime? Is there the same problem with Presenter 10?
Thanks a lot for your support once more
TOPICS
Presenter
Views
222
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
My version of Adobe Presenter is Presenter 9.0.2
Votes
Translate
Translate
Report
Report
LEGEND ,
Inserting an FLV shouldn't prompt for Quicktime. As I recall, only importing MP4 content required the use of QuickTime.
Are you able to insert video without Quicktime? You don't say what is or is not happening when you import a video.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 02, 2015 Mar 02, 2015
I can import FLV videos but once that I try to see the presentation, none video is reproduced in the slide (image attached). However, I have no chance to import videos like .mpeg or h.264. It appears the message about the necessity of having Quicktime.
It seems that the video is not load so the only way that I have to import videos is using a .swf file with video bar.
Thanks in advance for your support.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
If you are willing to share the video file, I can look at it and see if I expereince the same issue. You may also need to contact support to see if they can provide any insight about why Presenter is acting like this.
If you are able to share the video, you can PM me a link or email it to me. My email is jorma[at]realeyesconnect.com
Votes
Translate
Translate
Report
Report
Resources
Help resources
