2 Replies Latest reply on Feb 27, 2015 9:12 AM by elearning_dude
    Fine in Chrome but not on IE11
    elearning_dude Level 1
      I'm running into an issue where the composition works fine in Chrome but does not work in IE (version 11).
      I have an EA composition that contains 3 layers:
      1. An image of a tape measure.
      2. A shape (triangle)
      3. A textfield
      When the user drags the triangle across the X axis (I'm using jquery for this) and stops the drag, I want to evaluate where they are 'pointing' the triangle at in relation to the marks on the tape measure. And, if the triangle is between ### and ### of X then I write that measurement to the textfield. This works fine in Chrome but not in IE.
      On the Stage I have the following code:
      sym.setVariable("FEEDBACK", "NOT SET YET");
      $(function () {
         sym.$("triangle_slider").draggable({
        axis: 'x',
        stop: function () {
        // get the x position of the triangle_slider
        var position = sym.$("triangle_slider").position();
        var x = sym.$("triangle_slider").offset().left;
        measure = Math.trunc(x);
        switch (measure) {
                                  case 15:
                                      sym.$('FEEDBACK_TXT').html('1"');
                                      break;
                                  case 16:
                                      break;
                                  case 17:
                                      break;
                                  case 18:
                                      break;
                                  case 37:
                                      sym.$('FEEDBACK_TXT').html('1/16"');
                                      break;
                                  case 38:
                                      break;
                                  case 59:
                                      sym.$('FEEDBACK_TXT').html('1/8"');
                                      break;
                                  case 60:
                                      break;
                                  case 82:
                                      sym.$('FEEDBACK_TXT').html('3/16"');
                                      break;
                                  case 83:
                                      break;
                                  case 103:
                                      sym.$('FEEDBACK_TXT').html('1/4"');
                                      break;
                                  case 104:
                                      break;
                                  case 105:
                                      break;
                                  case 125:
                                      sym.$('FEEDBACK_TXT').html('5/16"');
                                      break;
                                  case 126:
                                      break;
                                  case 148:
                                      sym.$('FEEDBACK_TXT').html('3/8"');
                                      break;
                                  case 149:
                                      break;
                                  case 150:
                                      break;
                                  case 171:
                                      sym.$('FEEDBACK_TXT').html('7/16"');
                                      break;
                                  case 172:
                                      break;
                                  case 193:
                                      sym.$('FEEDBACK_TXT').html('1/2"');
                                      break;
                                  case 194:
                                      break;
                                  case 195:
                                      break;
                                  case 214:
                                      sym.$('FEEDBACK_TXT').html('9/16"');
                                      break;
                                  case 215:
                                      break;
                                  case 236:
                                      sym.$('FEEDBACK_TXT').html('5/8"');
                                      break;
                                  case 237:
                                      break;
                                  case 238:
                                      break;
                                  case 257:
                                      sym.$('FEEDBACK_TXT').html('11/16"');
                                      break;
                                  case 258:
                                      break;
                                  case 277:
                                      sym.$('FEEDBACK_TXT').html('3/4"');
                                      break;
                                  case 278:
                                      break;
                                  case 279:
                                      break;
                                  case 300:
                                      sym.$('FEEDBACK_TXT').html('13/16"');
                                      break;
                                  case 301:
                                      break;
                                  case 322:
                                      sym.$('FEEDBACK_TXT').html('7/8"');
                                      break;
                                  case 323:
                                      break;
                                  case 324:
                                      break;
                                  case 345:
                                      sym.$('FEEDBACK_TXT').html('15/16"');
                                      break;
                                  case 346:
                                      break;
                                  case 366:
                                      sym.$('FEEDBACK_TXT').html('2"');
                                      break;
                                  case 367:
                                      break;
                                  case 368:
                                      break;
                                  case 369:
                                      break;
                                  case 370:
                                      break;
                                  case 392:
                                      break;
                                  case 393:
                                      break;
                                  case 412:
                                      break;
                                  case 413:
                                      break;
                                  case 414:
                                      break;
                                  case 433:
                                      break;
                                  case 412:
                                      break;
      Any assistance with this is greatly appreciated! I thought it might be a decimal issue so I added in the truncation method but that doesn't do any good.
        • 1. Re: Fine in Chrome but not on IE11
          To clarify - by "it doesn't work in IE11" what I mean specifically is:
          The value never gets written to the textfield and the triangle is no longer draggable once 'dropped' the first time.
          • 2. Re: Fine in Chrome but not on IE11
            Still not sure what did it but I wound up going back to another, similar composition that I had put together months ago and just modified that. Here is the working code, for others who may run into a similar issue:
            sym.setVariable("CURRENT_SELECTION", "0");
            $(function () {
              axis: 'x',
              stop: function () {
              // 1"
              if (x >= 8 && x <= 12) {
              FEEDBACK = '1"';
              sym.$('FEEDBACK_TXT').html(FEEDBACK);
              } else if (x >= 30 && x <= 34) {
              FEEDBACK = '1/16"';
              } else if (x >= 52 && x <= 56) {
              FEEDBACK = '1/8"';
              } else if (x >= 75 && x <= 78) {
              FEEDBACK = '3/16"';
              } else if (x >= 96 && x <= 100) {
              FEEDBACK = '1/4"';
              } else if (x >= 118 && x <= 121) {
              FEEDBACK = '5/16"';
              } else if (x >= 141 && x <= 145) {
              FEEDBACK = '3/8"';
              } else if (x >= 164 && x <= 167) {
              FEEDBACK = '7/16"';
              } else if (x >= 186 && x <= 190) {
              FEEDBACK = '1/2"';
              } else if (x >= 207 && x <= 210) {
              FEEDBACK = '9/16"';
              } else if (x >= 229 && x <= 233) {
              FEEDBACK = '5/8"';
              } else if (x >= 250 && x <= 253) {
              FEEDBACK = '11/16"';
              } else if (x >= 270 && x <= 274) {
              FEEDBACK = '3/4"';
              } else if (x >= 293 && x <= 296) {
              FEEDBACK = '13/16"';
              } else if (x >= 315 && x <= 319) {
              FEEDBACK = '7/8"';
              } else if (x >= 339 && x <= 342) {
              FEEDBACK = '15/16"';
              } else if (x >= 360 && x <= 364) {
              FEEDBACK = '2"';
              FEEDBACK = '2"';
              } else if (x >= 385 && x <= 388) {
              FEEDBACK = '1/16"';
              } else if (x >= 405 && x <= 409) {
              FEEDBACK = '1/8"';
              } else if (x >= 426 && x <= 429) {
              FEEDBACK = '3/16"';
              } else {
              FEEDBACK = '';
