4 Replies Latest reply on Mar 2, 2015 12:37 PM by goofydiver
    Audio keeps dropping out. Orignal file audio is ok.
    goofydiver
        • 1. Re: Audio keeps dropping out. Orignal file audio is ok.
          A.T. Romano Level 7
          goofydiver
          What version of Premiere Elements and on what computer operating system is it running?
          What are the properties of your source media? And, if possible, please tell us the brand/model/settings of the camera or device that recorded the audio.
          Is the audio a separate audio file or a component in an video audio file?
          What is your project preset?
          Thank you.
          ATR
          • 3. Re: Audio keeps dropping out. Orignal file audio is ok.
            A.T. Romano Level 7
            goofydiver
            Thanks for your reply, but it was posted without a message.
            When your schedule permits, please try again to post the information requested.
            We are eager to see you move forward with your Premiere Elements workflow, and we believe that
            the answers to the questions will be the start of us helping you achieve that goal.
            Thank you.
            ATR
            • 4. Re: Audio keeps dropping out. Orignal file audio is ok.
              goofydiver Level 1
              system is it running? Version 13, PC with Windows 7
                   What are the properties of your source media? Do not understand what
              you are looking for. But hare is some info
                   Length 00:01:23 Size 311MB, Frame Width 1920, Frame Height 1080,
              Frame Rate 29 frames/sec, data rate 29977kbps, total bitrate 31616kbps
              camera or device that recorded the audio. Canon 70d, default settings
              file? Component of video
                    What is your project preset? default
                    Also I was able to reload orginal file and there was no audio drop
              out. But I need to understand what can cause this issue. But when I
              load this file into Power Point
                   I am also having issues playing the saved file (for view on
              computer). The audio drops out after about 20 second, video continues
              to play. This did not happen with the orginal file that had the audio
              drop outs in premiere. What dropped out in Premiere also dropped out
              in Power Point.
                   If needed I can send you the file.
                   Thank you for your quick response
                   Ron
