7 Replies Latest reply on Feb 28, 2015 10:02 AM by Kai Rübsamen
    linked text frame in enumeration
    hamdifem Level 1
      in one document there are many embedded text frame (object style applied = "myObjSty1")
      I want to write increasing numbers
      I tried to write but did not
      Can you help me in this regard
      Thank you in advance
      var sNo = 1;
      var doc = app.activeDocument;
      app.findGrepPreferences = app.changeGrepPreferences = null;
      app.findGrepPreferences.findWhat = "~a";
      var found = doc.findGrep();
      for(var i =found.length-1;i>=0;i--)
      if(found[i].allPageItems[0].appliedObjectStyle == myObjSty1)
           found[i].texts[0].select();
           app.changeGrepPreferences.changeTo = (++sNo);
           app.selection[0].changeGrep();
        • 1. Re: linked text frame in enumeration
          @handifem – you made several assumptions here not spoken out, when I am looking at your code (and reading about what you are trying to accomplish here). I might be wrong, but:
          What kind of sequence would you like to see?
          Order of anchored text frames in one single story?
          That would be: myStory.textFrames by their index numbers.
          Geometrical order throughout the story depending on their position on the page?
          Throughout the document?
          Something else?
          A GREP Search with "~a" may find the anchors representing the anchored text frames in a totally different order you would like to see.
          If we know something more, I think, we can help with the code as well.
          Uwe
          • 2. Re: linked text frame in enumeration
            hamdifem Level 1
            Text in the fluid
            anchored text frame (and applied them to the object style)
            in which "1" is writing. delete "1"
            to enumerate them, respectively,
            • 3. Re: linked text frame in enumeration
              @handifem – ah, ok. This is the easy case of sequence.
              You need no GREP search for this, simply iterate through all text frames of the story.
              Here an example where I assume, that are no other text frames anchored to the story that would not need numbering:
              var myStory = app.selection[0].parentStory;
              var myAnchoredTextFrames = myStory.textFrames.everyItem().getElements();
              for(var n=0;n<myAnchoredTextFrames.length;n++){
                  myAnchoredTextFrames[n].texts[0].contents = String(n+1);
              Of course you could decorate it with an if clause to single out all text frames with a specific object style.
              Uwe
              • 4. Re: linked text frame in enumeration
                hamdifem Level 1
                I could not connect to an object style
                To enumerate all frames
                if(myAnchoredTextFrames.appliedObjectStyle == myObjSty1){ //?
                • 5. Re: linked text frame in enumeration
                  1. You have to set the if clause inside the for loop.
                  2. You need to address every single text frame by its index
                  3. You need a counter to advance every time a match is found
                  //Object style is named "MyObjectStyle1"
                  //It is not nested in an ObjectStyleGroup !!
                  var myObjSty1 = app.documents[0].objectStyles.itemByName("MyObjectStyle1");
                  //Selection is the text frame or some text of the story you want to get the anchored text frames:
                  //Collecting ALL anchored text frames of the story to an array:
                  //Define a start number:
                  var myStartNumber = 1;
                  //Loop through the array of the text frames anchored:
                      //If my object style is assigned to the individual anchored text frame in that array:
                      if(myAnchoredTextFrames[n].appliedObjectStyle == myObjSty1){
                          //Set the contents to its text to the String of the current value of the start number variable
                          myAnchoredTextFrames[n].texts[0].contents = String(myStartNumber);
                          //If that is done, change the current number by adding the number 1:
                          myStartNumber = myStartNumber + 1;
                  Uwe
                  PS.: You should really look more into the basics for JavaScript before doing more work in ExtendScript.
                  • 6. Re: linked text frame in enumeration
                    Kai Rübsamen Level 4
                    Hi Guys,
                    although this seems to be answered a idea for a nonscripting way:
                    1. Create a paragraph style with autonumbering in a separate textframe with Autosize > width only.
                    2. Insert your textframe with the numbers
                    3. Write your text, add or delete some numbers, half way done
                    4. You will maybe discover a problem, that is shown in my screenshot. Sometimes the textframes and the followed character are overlapping. I think this is a bug.
                    5. Solution: Create a shortcut for "Recompose all stories immediately". After refreshing the document everything is fine, so no script needed
                    –Kai
                    • 7. Re: linked text frame in enumeration
                      After a further test: It seems that 'recompose' is not necessary, if the textframes column have a fixed width (to hold 2 or 3 numbers) and 'Autosize' is turned off.
