3 Replies Latest reply on Apr 20, 2015 7:54 AM by Szalam
    MacOS X 10.9.5 - AE CC 2014 Update Failure U44M1P7
    jollyrogeronesy
      I have been attempting to update After Effects and keep getting this failure error U44M1P7. In the resulting log that is generated it states the following:
      02/27/15 20:19:23:623 | [INFO] |  | OOBE | DE |  |  |  | 47038 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
      02/27/15 20:19:23:623 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Visit http://www.adobe.com/go/loganalyzer/ for more information
      02/27/15 20:19:23:623 | [INFO] |  | OOBE | DE |  |  |  | 47038 | START - Installer Session
      02/27/15 20:19:23:623 | [INFO] |  | OOBE | DE |  |  |  | 47038 | RIBS version: 8.0.0.22
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | OSX version: 10.9.5
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | ::START TIMER:: [Total Timer]
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | CHECK: Single instance running
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | CHECK : Credentials
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Load Deployment File
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | deploymentFile option not given
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | CHECK : Another Native OS installer already running
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Create Required Folders
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Assuming install mode
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Looking up install source path
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Sync Media DB ...
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | ::START TIMER:: [Sync Media DB]
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Pre check media db sync
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | End of Pre check media db sync. Exit code: 0
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | :: END TIMER :: [Sync Media DB] took 55 milliseconds (0.055 seconds) DTR = 509.091 KBPS (0.497159 MBPS)
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Ready to initialize session to start with ...
      02/27/15 20:19:23:628 | [INFO] |  | OOBE | DE |  |  |  | 47038 | ::START TIMER:: [CreatePayloadSession]
      02/27/15 20:19:23:629 | [INFO] |  | OOBE | DE |  |  |  | 47038 | -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
      02/27/15 20:19:23:629 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Updated source path: /Users/emerymar/Library/Caches/Adobe/AAMUpdater/AdobeAfterEffects-13.0.0-Trial/13.2.0
      02/27/15 20:19:23:629 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Updating media info for: {7285A3DC-7531-4D4E-B81E-116C229C8EAC}
      02/27/15 20:19:23:629 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Ignoring original data since install source is local
      02/27/15 20:19:23:629 | [INFO] |  | OOBE | DE |  |  |  | 47038 |   Type: 0, Volume Order: 1, Media Name: AfterEffects_CC_13_2_ftr
      02/27/15 20:19:23:629 | [INFO] |  | OOBE | DE |  |  |  | 47038 |   Path: /Users/emerymar/Library/Caches/Adobe/AAMUpdater/AdobeAfterEffects-13.0.0-Trial/13.2.0/pay loads/AdobeAfterEffects13SupportAll-051214043834/AdobeAfterEffects13SupportAll-05121404383 4.zip
      02/27/15 20:19:23:629 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Updating media info for: {AA97C46A-23AF-4B1A-BF1C-681522994961}
      02/27/15 20:19:23:629 | [INFO] |  | OOBE | DE |  |  |  | 47038 |   Path: /Users/emerymar/Library/Caches/Adobe/AAMUpdater/AdobeAfterEffects-13.0.0-Trial/13.2.0/pay loads/AdobeAfterEffects13AllTrial-051214042724/AdobeAfterEffects13AllTrial-051214042724.zi p
      02/27/15 20:19:23:629 | [INFO] |  | OOBE | DE |  |  |  | 47038 | --------------------  END  - Updating Media Sources -  END  --------------------
      02/27/15 20:19:23:632 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Supported RIBS version range: [0.0.0.0,8.0.0.22]
      02/27/15 20:19:23:632 | [INFO] |  | OOBE | DE |  |  |  | 47038 | ----------------- CreatePayloadSession: machine is x86 ---------------
      02/27/15 20:19:24:164 | [INFO] |  | OOBE | DE |  |  |  | 47038 | ______ Verify Dependency Subscribers ______
      02/27/15 20:19:24:164 | [INFO] |  | OOBE | DE |  |  |  | 47038 | BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
      02/27/15 20:19:24:164 | [INFO] |  | OOBE | DE |  |  |  | 47038 |   Adobe After Effects CC 2014 Support_13.2.0_AdobeAfterEffects13SupportAll 13.2.0.0 {7285A3DC-7531-4D4E-B81E-116C229C8EAC}: 0 (0,0)
      02/27/15 20:19:24:164 | [INFO] |  | OOBE | DE |  |  |  | 47038 |   Adobe After Effects CC 2014_13.2.0_AdobeAfterEffects13AllTrial 13.2.0.0 {AA97C46A-23AF-4B1A-BF1C-681522994961}: 0 (0,0)
      02/27/15 20:19:24:164 | [INFO] |  | OOBE | DE |  |  |  | 47038 | END Operation order for all session payloads: mediaGroup (requires,satisfies)
      02/27/15 20:19:24:166 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Patch Adobe After Effects CC 2014 Support_13.2.0_AdobeAfterEffects13SupportAll 13.2.0.0 {7285A3DC-7531-4D4E-B81E-116C229C8EAC} can be applied to product Adobe After Effects CC 2014 Support 13.0.0.0 {A55FF34C-8AA8-4BE2-ABCC-12BE48AE8DD5}
      02/27/15 20:19:24:167 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Patch Adobe After Effects CC 2014_13.2.0_AdobeAfterEffects13AllTrial 13.2.0.0 {AA97C46A-23AF-4B1A-BF1C-681522994961} can be applied to product Adobe After Effects CC 2014 13.0.0.0 {2B22C750-5C3B-4738-B621-BA786AC7A494}
      02/27/15 20:19:54:345 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Setting property "installSourcePath" to: /Users/emerymar/Library/Caches/Adobe/AAMUpdater/AdobeAfterEffects-13.0.0-Trial/13.2.0
      02/27/15 20:19:54:345 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Setting property "mode" to: silent
      02/27/15 20:19:54:345 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Setting property "updateManifestPath" to: /Users/emerymar/Library/Application Support/Adobe/AAMUpdater/1.0/Data/AdobeAfterEffects-13.0.0-Trial/13.2.0/13.2.0.xml
      02/27/15 20:19:54:345 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Setting property "workflow" to: updater
      02/27/15 20:19:54:345 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Overwrite property "extensionsOnly" to: 1
      02/27/15 20:19:54:345 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Overwrite property "mode" to: silent
      02/27/15 20:19:54:345 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Overwrite property "patchesOnly" to: 1
      02/27/15 20:19:54:345 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Overwrite property "updateManifestPath" to: /Users/emerymar/Library/Application Support/Adobe/AAMUpdater/1.0/Data/AdobeAfterEffects-13.0.0-Trial/13.2.0/13.2.0.xml
      02/27/15 20:19:54:345 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Overwrite property "workflow" to: updater
      02/27/15 20:19:54:346 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Found payload actions:
      02/27/15 20:19:54:346 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Deciding what installer mode to use...
      02/27/15 20:19:54:370 | [INFO] |  | OOBE | DE |  |  |  | 47038 | BEGIN Setting requested payload actions
      02/27/15 20:19:54:372 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Value returned on lookup of payload: Adobe After Effects CC 2014 Support_13.2.0_AdobeAfterEffects13SupportAll 13.2.0.0 {7285A3DC-7531-4D4E-B81E-116C229C8EAC} is: true
      02/27/15 20:19:54:372 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Action string for Adobe After Effects CC 2014 Support_13.2.0_AdobeAfterEffects13SupportAll 13.2.0.0 {7285A3DC-7531-4D4E-B81E-116C229C8EAC}  is install
      02/27/15 20:19:54:372 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Value returned on lookup of payload: Adobe After Effects CC 2014_13.2.0_AdobeAfterEffects13AllTrial 13.2.0.0 {AA97C46A-23AF-4B1A-BF1C-681522994961} is: false
      02/27/15 20:19:54:372 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Action string for Adobe After Effects CC 2014_13.2.0_AdobeAfterEffects13AllTrial 13.2.0.0 {AA97C46A-23AF-4B1A-BF1C-681522994961}  is install
      02/27/15 20:19:54:378 | [INFO] |  | OOBE | DE |  |  |  | 47038 | END Setting requested payload actions
      02/27/15 20:19:54:379 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Collected advanced path check information for INSTALLDIR
      02/27/15 20:19:54:379 | [INFO] |  | OOBE | DE |  |  |  | 47038 | INSTALLDIR is a well-formed path
      02/27/15 20:19:54:379 | [INFO] |  | OOBE | DE |  |  |  | 47038 | INSTALLDIR is not the root path
      02/27/15 20:19:54:379 | [INFO] |  | OOBE | DE |  |  |  | 47038 | INSTALLDIR is on a local volume
      02/27/15 20:19:54:379 | [INFO] |  | OOBE | DE |  |  |  | 47038 | INSTALLDIR is on a writable volume
      02/27/15 20:19:54:379 | [INFO] |  | OOBE | DE |  |  |  | 47038 | INSTALLDIR is not on a case sensitive volume
      02/27/15 20:19:54:379 | [INFO] |  | OOBE | DE |  |  |  | 47038 | INSTALLDIR passed path basic path validation: /Applications
      02/27/15 20:19:54:457 | [INFO] |  | OOBE | DE |  |  |  | 47038 | ::START TIMER:: [System check :{AA97C46A-23AF-4B1A-BF1C-681522994961}]
      02/27/15 20:19:54:466 | [INFO] |  | OOBE | DE |  |  |  | 47038 | In InstallPreSystemCheckProc
      02/27/15 20:19:54:466 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Custom action return code: 0
      02/27/15 20:19:54:466 | [INFO] |  | OOBE | DE |  |  |  | 47038 | :: END TIMER :: [System check :{AA97C46A-23AF-4B1A-BF1C-681522994961}] took 8 milliseconds (0.008 seconds)
      02/27/15 20:19:54:503 | [INFO] |  | OOBE | DE |  |  |  | 47038 | BEGIN InstallOperationsQueue Unordered operations
      02/27/15 20:19:54:503 | [INFO] |  | OOBE | DE |  |  |  | 47038 |   Adobe After Effects CC 2014 Support_13.2.0_AdobeAfterEffects13SupportAll 13.2.0.0 {7285A3DC-7531-4D4E-B81E-116C229C8EAC}:  with operation repair
      02/27/15 20:19:54:503 | [INFO] |  | OOBE | DE |  |  |  | 47038 |   Adobe After Effects CC 2014_13.2.0_AdobeAfterEffects13AllTrial 13.2.0.0 {AA97C46A-23AF-4B1A-BF1C-681522994961}:  with operation install
      02/27/15 20:19:54:503 | [INFO] |  | OOBE | DE |  |  |  | 47038 | END InstallOperationsQueue Unordered operations
      02/27/15 20:19:54:503 | [INFO] |  | OOBE | DE |  |  |  | 47038 | BEGIN InstallOperationsQueue Ordered operations
      02/27/15 20:19:54:503 | [INFO] |  | OOBE | DE |  |  |  | 47038 | END InstallOperationsQueue Ordered operations
      02/27/15 20:19:54:504 | [WARN] |  | OOBE | DE |  |  |  | 47038 | DW035: Patcher: Adobe After Effects CC 2014 Support_13.2.0_AdobeAfterEffects13SupportAll 13.2.0.0 {7285A3DC-7531-4D4E-B81E-116C229C8EAC} has already been applied. Patchers cannot be repaired/reinstalled, skipping this patcher
      02/27/15 20:19:54:534 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Payloads passed preflight validation.
      02/27/15 20:19:54:534 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Call PreSession Custom Hook
      02/27/15 20:19:54:534 | [INFO] |  | OOBE | DE |  |  |  | 47038 | ::START TIMER:: [Pre session :{AA97C46A-23AF-4B1A-BF1C-681522994961}]
      02/27/15 20:19:54:534 | [INFO] |  | OOBE | DE |  |  |  | 47038 | In InstallSessionOpenProc
      02/27/15 20:19:54:534 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Custom action return code: 0
      02/27/15 20:19:54:534 | [INFO] |  | OOBE | DE |  |  |  | 47038 | :: END TIMER :: [Pre session :{AA97C46A-23AF-4B1A-BF1C-681522994961}] took 0 milliseconds (0 seconds)
      02/27/15 20:19:54:534 | [INFO] |  | OOBE | DE |  |  |  | 47038 | BEGIN InstallOperationsQueue Unordered operations
      02/27/15 20:19:54:535 | [INFO] |  | OOBE | DE |  |  |  | 47038 |   Adobe After Effects CC 2014 Support_13.2.0_AdobeAfterEffects13SupportAll 13.2.0.0 {7285A3DC-7531-4D4E-B81E-116C229C8EAC}:  with operation repair
      02/27/15 20:19:54:535 | [INFO] |  | OOBE | DE |  |  |  | 47038 |   Adobe After Effects CC 2014_13.2.0_AdobeAfterEffects13AllTrial 13.2.0.0 {AA97C46A-23AF-4B1A-BF1C-681522994961}:  with operation install
      02/27/15 20:19:54:535 | [INFO] |  | OOBE | DE |  |  |  | 47038 | END InstallOperationsQueue Unordered operations
      02/27/15 20:19:54:535 | [INFO] |  | OOBE | DE |  |  |  | 47038 | BEGIN InstallOperationsQueue Ordered operations
      02/27/15 20:19:54:535 | [INFO] |  | OOBE | DE |  |  |  | 47038 | END InstallOperationsQueue Ordered operations
      02/27/15 20:19:54:570 | [WARN] |  | OOBE | DE |  |  |  | 47038 | DW035: Patcher: Adobe After Effects CC 2014 Support_13.2.0_AdobeAfterEffects13SupportAll 13.2.0.0 {7285A3DC-7531-4D4E-B81E-116C229C8EAC} has already been applied. Patchers cannot be repaired/reinstalled, skipping this patcher
      02/27/15 20:19:54:570 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Skipping payload Adobe After Effects CC 2014 Support_13.2.0_AdobeAfterEffects13SupportAll 13.2.0.0 {7285A3DC-7531-4D4E-B81E-116C229C8EAC} as payload is not cached
      02/27/15 20:19:54:646 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Calling the custom action code for pre-install for payload Adobe After Effects CC 2014_13.2.0_AdobeAfterEffects13AllTrial 13.2.0.0 {AA97C46A-23AF-4B1A-BF1C-681522994961}
      02/27/15 20:19:54:646 | [INFO] |  | OOBE | DE |  |  |  | 47038 | ::START TIMER:: [Pre payload :{AA97C46A-23AF-4B1A-BF1C-681522994961}]
      02/27/15 20:19:54:646 | [INFO] |  | OOBE | DE |  |  |  | 47038 | In PrePayloadInstallProc
      02/27/15 20:19:54:646 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Custom action return code: 0
      02/27/15 20:19:54:646 | [INFO] |  | OOBE | DE |  |  |  | 47038 | :: END TIMER :: [Pre payload :{AA97C46A-23AF-4B1A-BF1C-681522994961}] took 0 milliseconds (0 seconds)
      02/27/15 20:19:54:646 | [INFO] |  | OOBE | DE |  |  |  | 47038 | ::START TIMER:: [Payload Operation :{AA97C46A-23AF-4B1A-BF1C-681522994961}]
      02/27/15 20:19:54:649 | [INFO] |  | OOBE | DE |  |  |  | 47411 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
      02/27/15 20:19:54:649 | [INFO] |  | OOBE | DE |  |  |  | 47411 | Installer Operation: PayloadInstaller
      02/27/15 20:19:54:649 | [INFO] |  | OOBE | DE |  |  |  | 47411 | Request to install payload
      02/27/15 20:19:54:659 | [INFO] |  | OOBE | DE |  |  |  | 47411 | Payload Adobe After Effects CC 2014_13.2.0_AdobeAfterEffects13AllTrial 13.2.0.0 {AA97C46A-23AF-4B1A-BF1C-681522994961}: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE6/resources
      02/27/15 20:20:10:230 | [INFO] |  | OOBE | DE |  |  |  | 47411 | Extracting assets complete. Number assets: 1
      02/27/15 20:20:10:231 | [INFO] |  | OOBE | DE |  |  |  | 47411 | CustomizedPatch property not found in database
      02/27/15 20:20:10:231 | [INFO] |  | OOBE | DE |  |  |  | 47411 | Beginning installation for payload at /Users/emerymar/Library/Caches/Adobe/AAMUpdater/AdobeAfterEffects-13.0.0-Trial/13.2.0/pay loads/AdobeAfterEffects13AllTrial-051214042724/Install.db
      02/27/15 20:20:10:285 | [ERROR] |  | OOBE | DE |  |  |  | 47411 | DS015: Unable to read symlink target of source file "/Applications/Adobe After Effects CC 2014/Plug-ins/Effects/mochaAE/(Mocha Support)/mocha AE CC.app/Contents/MacOS/mediaioserver.app/Contents/CodeResources"(Seq 213)
      02/27/15 20:20:10:285 | [WARN] |  | OOBE | DE |  |  |  | 47411 | DW063: Command ARKCopySymlinkCommand failed.(Seq 213)
      02/27/15 20:20:10:286 | [INFO] |  | OOBE | DE |  |  |  | 47411 | Completing installation for payload at /Users/emerymar/Library/Caches/Adobe/AAMUpdater/AdobeAfterEffects-13.0.0-Trial/13.2.0/pay loads/AdobeAfterEffects13AllTrial-051214042724/Install.db
      02/27/15 20:20:11:713 | [INFO] |  | OOBE | DE |  |  |  | 47038 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
      02/27/15 20:20:11:713 | [INFO] |  | OOBE | DE |  |  |  | 47038 | :: END TIMER :: [Payload Operation :{AA97C46A-23AF-4B1A-BF1C-681522994961}] took 17068 milliseconds (17.068 seconds) DTR = 21.5608 KBPS (0.0210555 MBPS)
      02/27/15 20:20:11:750 | [INFO] |  | OOBE | DE |  |  |  | 47038 | User specified overrideFile:
      02/27/15 20:20:11:752 | [INFO] |  | OOBE | DE |  |  |  | 47038 | The csu inventory was not updated for payload Adobe After Effects CC 2014_13.2.0_AdobeAfterEffects13AllTrial 13.2.0.0 {AA97C46A-23AF-4B1A-BF1C-681522994961}, value of local var is -1
      02/27/15 20:20:11:753 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Calling the ROLLBACK custom action code for pre-install for payload Adobe After Effects CC 2014_13.2.0_AdobeAfterEffects13AllTrial 13.2.0.0 {AA97C46A-23AF-4B1A-BF1C-681522994961}
      02/27/15 20:20:11:753 | [INFO] |  | OOBE | DE |  |  |  | 47038 | ::START TIMER:: [Pre payload :{AA97C46A-23AF-4B1A-BF1C-681522994961}]
      02/27/15 20:20:11:753 | [INFO] |  | OOBE | DE |  |  |  | 47038 | In PrePayloadInstallProc
      02/27/15 20:20:11:753 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Custom action return code: 0
      02/27/15 20:20:11:753 | [INFO] |  | OOBE | DE |  |  |  | 47038 | :: END TIMER :: [Pre payload :{AA97C46A-23AF-4B1A-BF1C-681522994961}] took 0 milliseconds (0 seconds)
      02/27/15 20:20:13:753 | [INFO] |  | OOBE | DE |  |  |  | 47038 | No operation.  We're done:
      02/27/15 20:20:15:767 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Total components installed: 0
      02/27/15 20:20:15:767 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Total components repaired: 0
      02/27/15 20:20:15:767 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Total components removed: 0
      02/27/15 20:20:15:767 | [WARN] |  | OOBE | DE |  |  |  | 47038 | DW050: The following payload errors were found during install:
      02/27/15 20:20:15:767 | [WARN] |  | OOBE | DE |  |  |  | 47038 | DW050:  - Adobe After Effects CC 2014 Support_13.2.0_AdobeAfterEffects13SupportAll: Patch already installed
      02/27/15 20:20:15:767 | [WARN] |  | OOBE | DE |  |  |  | 47038 | DW050:  - Adobe After Effects CC 2014_13.2.0_AdobeAfterEffects13AllTrial: Install failed
      02/27/15 20:20:15:767 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Call PostSession Custom Hook
      02/27/15 20:20:15:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 | ::START TIMER:: [Post session :{AA97C46A-23AF-4B1A-BF1C-681522994961}]
      02/27/15 20:20:15:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 | In InstallSessionCloseProc
      02/27/15 20:20:15:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Custom action return code: 0
      02/27/15 20:20:15:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 | :: END TIMER :: [Post session :{AA97C46A-23AF-4B1A-BF1C-681522994961}] took 0 milliseconds (0 seconds)
      02/27/15 20:20:15:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 | :: END TIMER :: [Total Timer] took 52641 milliseconds (52.641 seconds) DTR = 305.845 KBPS (0.298677 MBPS)
      02/27/15 20:20:16:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 | -------------------------------------- Summary --------------------------------------
      02/27/15 20:20:16:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 |  - 0 fatal error(s), 1 error(s)
      02/27/15 20:20:16:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 | OSX version: 10.9.5
      02/27/15 20:20:16:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 | ----------- Payload: Adobe After Effects CC 2014_13.2.0_AdobeAfterEffects13AllTrial 13.2.0.0 {AA97C46A-23AF-4B1A-BF1C-681522994961} -----------
      02/27/15 20:20:16:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 | ERROR: DS015: Unable to read symlink target of source file "/Applications/Adobe After Effects CC 2014/Plug-ins/Effects/mochaAE/(Mocha Support)/mocha AE CC.app/Contents/MacOS/mediaioserver.app/Contents/CodeResources"(Seq 213)
      02/27/15 20:20:16:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Please search the above error string(s) to find when the error occurred.
      02/27/15 20:20:16:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 | These errors resulted in installer Exit Code mentioned below.
      02/27/15 20:20:16:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 | -------------------------------------------------------------------------------------
      02/27/15 20:20:16:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Exit Code: 7 - Unable to complete Silent workflow.
      02/27/15 20:20:16:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 | Please see specific errors for troubleshooting. For example, ERROR: DS015 ...
      02/27/15 20:20:16:768 | [INFO] |  | OOBE | DE |  |  |  | 47038 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
      02/27/15 20:20:16:769 | [INFO] |  | OOBE | DE |  |  |  | 47038 | END - Installer Session
      02/27/15 20:20:16:769 | [INFO] |  | OOBE | DE |  |  |  | 47038 | *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
      This is pretty annoying. Anyone have a fix for this.
