1 Reply Latest reply on Feb 28, 2015 7:47 AM by A.T. Romano
    how do you exposrt projects ins 60fps?
    samanthac57462319
      I am trying to upload to YouTube but I need my files to be in 60fps or else they will not upload. Please help!
        • 1. Re: how do you exposrt projects ins 60fps?
          A.T. Romano Level 7
          samanthac
          What version of Premiere Elements and on what computer operating system is it running.
          Premiere Elements' built in YouTube feature does not have a preset for an upload from there using a frame rate of 60 progressive frames per second.
          I am assuming that your "60 fps" = 60  frames per second and not 60 fields per second (representing 29.97/30 frames per second).
          What you will need to do is export your Timeline to a file with a 60 progressive frames per second frame rate. And, from its hard drive save location,
          you upload the file to YouTube at the YouTube web site.
          If consistent with your project, a suggested export might be (for NTSC set up and project settings for 1920 x 1080p30)
          Publish+Share
          Computer
          AVCHD
          with Presets = MP4 H.264 1920 x 1080p30
          then under the Advanced Button of the preset, you customize the preset so that it is for MP4 H.264 1920 x 1080p60 instead of p30.
          Please supply more details so that we can customize the reply to what you are actually using.
          Thank you.
          ATR
