0 Replies Latest reply on Feb 28, 2015 3:39 AM by SourceSkyBoxer
    Adobe Air is very smiller than Zinc App - Reposition and Resize not working?
    SourceSkyBoxer Level 1
      Hello guys, i have found and readden nice solution like NativeWindow was saved positions and sizes If i close Adobe Air App and i open again like NativeWindow was moved and resized. It is very simple working. And it works fine. 100 % Good! But how does it work with Zinc App because it doesn't work for positions and sizes. How do i fix? I have upgraded code from FileSerializer.as With mdm.Script:
      package
        import flash.events.Event;
        import flash.net.URLRequest;
        import flash.net.URLStream;
        import flash.utils.ByteArray;
        import mdm.Application;
        import mdm.FileSystem;
        import mdm.System;
        public class FileSerializer
        public static function WriteObjectToFile(object:Object, filename:String):void
        var fileExists:Boolean = mdm.FileSystem.fileExists(mdm.Application.path+filename);
        var outByte:ByteArray = new ByteArray();
        outByte.writeObject(object);
        if(fileExists == false)
        mdm.FileSystem.saveFile(mdm.Application.path+filename, "");
        mdm.FileSystem.BinaryFile.setDataBA(outByte);
        mdm.FileSystem.BinaryFile.writeDataBA(mdm.Application.path+filename);
        private static var stream:URLStream;
        public static function ReadObjectfromFile(filename:String):Object
        var obj:Object;
        stream = new URLStream();
        stream.addEventListener(Event.COMPLETE, function(evt:Event):void
        obj = stream.readObject();
        stream.close();
        stream.load(new URLRequest(filename));
        return obj;
        return null;
      That is improved to mdm.Script and it saves sometimes.
      And i have create UserPref.as
      package
        public class UserPref
        public var zincForm:String = "MainForm";
        public var zincType:String = "sizeablestandard";
        //public var zincSWF:String = "MainApp.swf";
        public var zincPosX:Number;
        public var zincPosY:Number;
        public var zincWidth:Number;
        public var zincHeight:Number;
      And i create MainApp.mxml
      <mx:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
        xmlns:mx="library://ns.adobe.com/flex/mx"
        layout="absolute" applicationComplete="applicationCompleteHandler(event)" creatingComplete="creationCompleteHandler(event)">
        <fx:Script>
        <![CDATA[
        import mdm.Event;
        import mdm.Forms;
        import mdm.mdmForm;
        import mx.events.FlexEvent;
        private var up:UserPref;
        private var form:mdmForm;
        protected function applicationCompleteHandler(event:FlexEvent):void
        mdm.Application.init();
        this.up.zincPosX = this.form.x;
        this.up.zincPosY = this.form.y;
        this.up.zincWidth = this.form.width;
        this.up.zincHeight = this.form.height;
        FileSerializer.WriteObjectToFile(this.up, "pref.zup");
        mdm.Application.onAppExit = function (appevt:flash.events.Event):void
        mdm.Application.exit();
        mdm.Application.enableExitHandler();
        protected function creationCompleteHandler(event:flash.events.Event):void
        this.up = FileSerializer.ReadObjectfromFile("pref.zup") as UserPref;
        if(up) {
        mdm.Application.onFormReposition = function(rpevt:mdm.Event):void
        this.form.x = up.zincPosX;
        this.form.y = up.zincPosY;
        mdm.Application.onFormResize = function(rsevt:mdm.Event):void
        this.form.width = up.zincWidth;
        this.form.height = up.zincHeight;
        }else
        this.up = new UserPref();
        </fx:Script>
        <fx:Declarations>
        <!-- Platzieren Sie nichtvisuelle Elemente (z. B. Dienste, Wertobjekte) hier -->
        </fx:Declarations>
      </mx:Application>
      And i recompile with Zinc Studio 4.0.22 than i try reposition and resize with Zinc Window than i close since saved files and i open again. But why does it not reposition and resize?
      How do i fix? Can somebody help me?
      Thanks best regards Jens Eckervogt
