10 Replies Latest reply on May 14, 2018 9:38 PM by irfanhossain
    Redaction Javascript for batch or single use
    Flonas Level 1
      I regularly need to redact certain documents from 2 different sources. For each source, the areas for redaction are the same. One source has 2 areas that need redaction and the other source has 4 areas that need to be redacted on each page, anywhere from 9-10 pages per document. What I am trying to do is automate this process as it takes a lot of time to do this manually all the time. I am familiar with creating actions in Adobe so my thought is to create an action that can be applied to batches of documents from each source. Currently the action deletes a page (also part of the process) then I have "execute a javascript” then remove hidden information. The part I need help with is the "execute a javascript" part.
      I have looked around some and found that a drawing markup tool rectangle has default coordinates or rotated coordinates. I do not need to have anything to do with the rotated coordinate conversions. In order to find the default X/Y coordinates of the four corners of a drawing markup rectangle I can use this script successfully:
      "this.getAnnots()[0].rect
      this allows me to draw a box around the areas that I want redacted and then  get the X/Y coordinates to use in the javascript to tell it which areas I want redacted. Essentially I am looking for a javascript that will allow me to define a set of coordinates for the areas I want to redact(they will always be the same and I will get them using the above script unless otherwise directed) , mark them for redaction and apply the redactions. If the coordinates provided by the above script will work great. If I need to find the quad coordinates i will need separate script or instruction on how to find the quad coordinates for the areas I want redacted. Please help! I am using a rMBP that is about 2 months old and Adobe Acrobat X Pro
        • 1. Re: Redaction Javascript for batch or single use
          You have a lot more work to do.
          Automating Redaction with Acrobat JavaScript by Thom Parker
          • 2. Re: Redaction Javascript for batch or single use
            Flonas Level 1
            I actually read this initially. The quad reference lookup part did not seem to work properly, perhaps because it was written for AAP 9.0 7 years ago and I am using AAP X? Specifically this piece seems to be an issue:
            "var rct = getAnnots(this.pageNum)[0].rect;”
            Perhaps because the rectangle tool is no longer part of the annotation tool set, it is now part of the drawing markup tool set and I do not know how to adjust the reference or if it would even work.
            Thoughts?
            Tom
            • 3. Re: Redaction Javascript for batch or single use
              There are changes with every update to all products.
              I wrote a function to perform a reaction using that article with Acrobat 9 and have used it with both Acrobat 9 and XI without additional changes.
              If you carefully read the article and the following comments, you should find a correction to the code.
              Running the code for the first example  I get the following result:
              var left = rct[0];
              var right = rct[2];
              var top = rct[3];
              var bot = rct[1];
              qd = [ [left, top, right, top, left, bot, right, bot] ] qd.toSource();
              SyntaxError: missing ; before statement
              6:Console:Exec
              undefined
              So I see the error is in line 6
              That line should be 2 lines , or a semicolon needs to inserted after "bot]]; qd.toSource();
              So running the following code:
              var left = rct[0];
              var right = rct[2];
              var top = rct[3];
              var bot = rct[1];
              qd = [ [left, top, right, top, left, bot, right, bot] ]; qd.toSource();
              Provides the following result:
              [[472.81201171875, 661.822021484375, 580.81201171875, 661.822021484375, 472.81201171875, 643.4219970703125, 580.81201171875, 643.4219970703125]]
              • 4. Re: Redaction Javascript for batch or single use
                Flonas Level 1
                Great! Thanks
                Tom
                • 5. Re: Redaction Javascript for batch or single use
                  Flonas Level 1
                  Ok,
                  So far so good, that helped quite a bit and I was able to get the quads for the 2 areas I would like to redact. Now when I compile the code from the bottom of the article and follow the instructions:
                  “To use this code, copy it to the Acrobat JavaScript Console <https://acrobatusers.com/tutorials/2006/javascript_console/>. Select and run Parts #1 and #2. Then select the code for the scheme that will be used on the current document and run it. Run only one scheme on one document.”
                  I am not able to get past selecting and running parts #1 and #2.  Below is my code and the resulting error, I do not really know how to troubleshoot this code to tell what is missing from line 5. I believe it is because the quadList being referred to is not defined as such anywhere?
                  // Part 1: Quads for the different Redaction areas
                  var qdTitle = [[26.8800048828125, 779.9100341796875, 552.3200073242188, 779.9100341796875, 26.8800048828125, 693.510009765625, 552.3200073242188, 693.510009765625]];
                  var qdRFL = [[26.8800048828125, 693.510009765625, 87.04000854492188, 693.510009765625, 26.8800048828125, 656.3900146484375, 87.04000854492188, 656.3900146484375]];
                  //Part 2: Function for adding Redact Annotations to a PDF function
                  AddMyRedacts(quadList)  {
                       for(var pg=1; pg<this.numPages; pg++)
                            for(var index=0; index<quadList.length; index++) {
                                 this.addAnnot({
                                      type:"Redact", page:pg,
                                      quads:quadList[index]
                  5:Console:Exec
                  undefined
                  Please help
                  Tom
                  • 6. Re: Redaction Javascript for batch or single use
                    urielk13361039 Level 1
                    Hi Tom,
                    I believe the problem is that AddMyRedacts is not defined properly. Add the word function before it and that should fix it.
                    It should look like this:
                    function AddMyRedacts(quadList)  {
                         for(var pg=1; pg<this.numPages; pg++){
                                   this.addAnnot({
                    // Part3: Applying the redactions
                    AddMyRedacts([qdTitle, qdRFL]);
                    this.applyRedactions({bKeepMarks: false, bShowConfirmation: true, cProgText: "It's going away" });
                    P.S: To run this code put it in the console, select it all with ctrl+a, and then press ctrl+enter.
                    • 7. Re: Redaction Javascript for batch or single use
                      Flonas Level 1
                      Urielk,
                      This was outstanding, thank you for the help, this is now running successfully, however I have one issue. I only want this script to run and apply to one page of a certain document that I get regularly and the page I got the script from says:
                      "This code walks through the document pages and adds Redact Annotations. One annotation is added for each quad in the list. The first page of the file is a title page, so it’s not included in the redaction.”
                      How do I adjust the Part 2 script so that it only applies to the first page instead of vice versa?
                      • 8. Re: Redaction Javascript for batch or single use
                        Remove the first for-loop and change this parameter:
                        page:pg
                        To:
                        page:0
                        • 9. Re: Redaction Javascript for batch or single use
                          Flonas Level 1
                          Try67,
                          this worked fantastically. I have been able to successfully compile an action in Acrobat that full process documents of like kind either singly or by the folder. Thank you so much.
                          Tom
                          • 10. Re: Redaction Javascript for batch or single use
                            irfanhossain Level 1
                            Hi
                            I found a problem at Auto redact JavaScript source. Here is the final edited javascript for redaction .
                            var qdFirstName = [[455.565673828125, 966.10888671875, 515.7841186523438, 966.10888671875, 455.565673828125, 917.2359619140625, 515.7841186523438, 917.2359619140625]];
                            var qdLastName = [[454.69293212890625, 759.2715454101562, 514.911376953125, 759.2715454101562, 454.69293212890625, 710.3986206054688, 514.911376953125, 710.3986206054688]];
                            var qdAdress = [[453.8201904296875, 639.7073364257812, 514.0386352539062, 639.7073364257812, 453.8201904296875, 615.27099609375, 514.0386352539062, 615.27099609375]];
                            var qdCityState = [[450.32928466796875, 562.0343017578125, 517.529541015625, 562.0343017578125, 450.32928466796875, 499.19769287109375, 517.529541015625, 499.19769287109375]];
                            var qdSocSec = [[447.71112060546875, 436.2337646484375, 514.911376953125, 436.2337646484375, 447.71112060546875, 396.9609375, 514.911376953125, 396.9609375]];
                            var qdAlow = [[449.45654296875, 334.12420654296875, 516.6567993164062, 334.12420654296875, 449.45654296875, 294.85137939453125, 516.6567993164062, 294.85137939453125]];
                            var qdExempt = [[446.83837890625, 241.61474609375, 514.0386352539062, 241.61474609375, 446.83837890625, 183.26904296875, 514.0386352539062, 183.26904296875]];
                            var qdextra = [[453.8201904296875, 862.2538452148438, 514.0386352539062, 862.2538452148438, 453.8201904296875, 813.3809204101562, 514.0386352539062, 813.3809204101562]];
                                           this.addAnnot({
                            AddMyRedacts([qdFirstName, qdLastName, qdAdress, qdCityState, qdSocSec, qdAlow, qdExempt, qdextra]);
                            Just Change the var code . You can find these code from rectangle tools.
                            If you Have any problem you can contact with me.
                            My Fiverr Account is : https://www.fiverr.com/healerirfan
                            Thank-you
