4 Replies Latest reply on Mar 1, 2015 3:02 PM by K_Georgiadis
    printing a 8.5 x 11 print
    K_Georgiadis
      I find Lr's Print Module extremely confusing, especially because of the image Preview that I am unable to correlate with the final result.
      In Lightroom's Develop Module I cropped my image to 8.5 x 11 and I want to print it on 8.5 x 11 photo paper with a uniform 20-pixel white margin all around it. After wasting a lot of good photo paper in abortive attempts, I must declare total defeat and request your kind guidance.
      Your help will be greatly appreciated!
        • 1. Re: printing a 8.5 x 11 print
          Just Shoot Me Adobe Community Professional
          First off printing paper isn't defined by pixels per inch. If you want to print to a paper size of 8.5 x 11 inches and have a equal boarder of white around the whole image then you have to decide what that 20 pixel dimension is in inches. 1/4 inch around the image? 3/8" around? Then double that and crop to that size. So if it is 1/4" you would need to crop to 8 x 10.5.
          Sorry I don't use the LR print module much if at all. I print from Photoshop but the same applies. When I do print I usually print to a paper size of 13 x 19. Which works very well for 3/2 aspect ratio with a 1/2" boarder around the image on paper. So I crop and or set resolution to equal 12 x 18.
          Then again you have to take into consideration your printers specs. Can it print to within 1/4" of the paper edge? Even some printers that can print boarder-less have restrictions as to the margin when not set to boarder-less printing.
          • 2. Re: printing a 8.5 x 11 print
            K_Georgiadis Level 1
            Thank you. I think that I have just figured out, using the Lightroom Print Module: (1) crop to 8.5 x 11 (2) in the print module allow 0.25 inch margin on each side (3) enable bordered printing in the (Canon) Printer Properties dialog box
            • 3. Re: printing a 8.5 x 11 print
              That will work but then LR is reducing your image to fit the paper size with boarder.
              Glad it is working out.
              • 4. Re: printing a 8.5 x 11 print
                Yes, that is true. Next time I am going to try your approach. Thanks again!
