Hey guys, been out of the coding loop for quite a bit. Doing a quick proof of concept and have two simple code pieces to put together. Here's what I"m trying to accomplish.
1) mimic a simple parallax webpage, drag up and down to view content
2) have the ability within each content "band" to go left and right if necessary
so here's what I've done:
- built a large parent movieclip called ONEPAYLAYOUT in the code.
- have sub/child movieclips called bands.
- found code to allow me to scroll up and down
1) so with the code from a tutorial, it does what I need for the scrolling but for some reason, right when you launch it jumps down to band 2. I have no clue why. Band 1 is perfectly aligned with the stage, so it should launch and just stay put. So I don't know if anyone can see in the code below why it does some auto adjustment. My code is below, hope someone can see the issue.
2) a future direction helper. If I put a button in somehting like band 2 to have a trigger for band 2 to go to it's second keyframe, a different picture. I know that with the event listener on the main parent movieclip it does not work or pick up the click of a child/nested movieclilp. I know this has to have been done a million times because I see it all over the web and in apps. Any ideas?
import flash.events.MouseEvent;
import flash.geom.Point;
import flash.events.Event;
import flash.geom.Rectangle;
var destination:Point=new Point();
var dragging:Boolean=false;
var speed:Number=5;
var offset:Point=new Point(); // our offset
ONEPAGELAYOUT.addEventListener(MouseEvent.MOUSE_DOWN,startdrag);
stage.addEventListener(MouseEvent.MOUSE_UP,stopdrag);
ONEPAGELAYOUT.addEventListener(Event.ENTER_FRAME,followmouse);
var bounds:Rectangle=new Rectangle(0,719.95,stage.stageWidth,stage.stageHeight);
function followmouse(e:Event):void{
if(dragging){
destination.y=mouseY;
ONEPAGELAYOUT.y-=(ONEPAGELAYOUT.y-(destination.y-offset.y))/speed;
if(ONEPAGELAYOUT.y>bounds.top){
ONEPAGELAYOUT.y=bounds.top;
if(ONEPAGELAYOUT.y<-ONEPAGELAYOUT.height+bounds.bottom){
ONEPAGELAYOUT.y=-ONEPAGELAYOUT.height+bounds.bottom;
function startdrag(e:MouseEvent):void{
offset.y=ONEPAGELAYOUT.mouseY*ONEPAGELAYOUT.scaleY;
dragging=true;
function stopdrag(e:MouseEvent):void{
dragging=false;
then use:
var speed:Number=5;
O
the code in followmouse is always executing (because of your enterframe listener) and that shouldn't be happening. you should only start that loop when a position change is needed and, after complete, you should remove that listener.
Hey Kglad, thanks for the reply. When I removed the event listener and then the full follow mouse function, the abiity to drag disappeared. It did line up the movieclip right, but I lost the function. Any idea as to why, both the start and stop drags are there, and an event listener...
try:
var speed:Number=5;
ONEPAGELAYOUT.removeEventListener(Event.ENTER_FRAME,followmouse);
Hey Kglad, it makes it draggable but loses the easing. think this may be just some wacky code. Looking into throwprops by greensock as I really just need a vertical scroller with drag and easing. that's it. nothing special
then use:
var speed:Number=5;
if(Math.ABS(ONEPAGELAYOUT.y-destination.y)<1){
ONEPAGELAYOUT.y=destination.y;
Hey K,
Ok so this makes no sense but it was something to do with the large Movieclip. So I put all my pages lined up, created sub mcs out of them. Then grouped them into a parent mc. Something in this process flash didn't like. So I grabbed an old file that I did something similar, exactly the same layout and creation process. It worked with that parent movieclip. I gutted out all the child mcs, put my new ones in and the behavior is gone. wtf.
