6 Replies Latest reply on Mar 10, 2015 11:51 AM by Silly-V
    Importing dataSet XML <p>whitespace</p> to create blank line
    Silly-V Adobe Community Professional
      I would like to import a dataset which contains a text-content data which has several <p>text</p> elements in it, one of them being a separating blank 'paragraph' designed to put a simple carriage-return into the bound text-area.
      What happens is that when I import such an XML file, the empty <p> tag has its whitespace ignored, and the blank line does not get produced.  Even when exporting a dataset with a variable which was produced from a textframe which has a blank line in between a topmost and bottom-most line, when importing back, the line disappears. Simply put, is there any way to make my desired blank line with any kind of setting or XML trickery? I already tried putting a nextline in CDATA in the 'empty' <p>, and setting the attribute 'xml:space="preserve"' on the empty <p>.BlankLine_XML_1.jpgBlankLine_XML_2.jpgBlankLine_XML_3.jpg
