7 Replies Latest reply on Mar 3, 2015 2:04 PM by natali.nac
    Search PDF
    natali.nac Level 1
      I've seen on this page how to implement the search functionality for a single word.. But what can I do if I want to search for entire senteces (or at least 2,3 words separated by space)?
        • 1. Re: Search PDF
          Search for the first one, and when you find it check if the following words
          after that match the rest of the words in your search phrase.
          • 2. Re: Search PDF
            You might want to study the Acrobat JavaScript API Reference for the getPageNthWord for the syntax and optional parameters. You will need to loop through the words on a page. If you need to check the words that a on different pages your script will be more complex.
            • 3. Re: Search PDF
              natali.nac Level 1
              Thanks for the idea..
              I came up with something like this (but it doesn't work everytime)
              /* Find */
              var temp=[];
              var pageArray = [];
              var string = "string to search";
              var phrase= [];
              phrase= string.split(" ");
              first= phrase[0];
              for (var p = 0; p < this.numPages; p++) {
                  control= 0;
                  for (var n = 0; n < this.getPageNumWords(p); n++) {
                      if (this.getPageNthWord(p, n) == first) {
                          a = n + 1;
                          control=control+1;
                          for (i = 1; i < phrase.length; i++) {
                              if (this.getPageNthWord(p, a) == phrase[i] && a< this.getPageNumWords(p)) {
                                  control=control+1;
                                  a=a+1;
                              } else break;
                      if (control== phrase.length) {
                              pageArray.push(p);
                              break;
              • 4. Re: Search PDF
                Bernd Alheit Adobe Community Professional & MVP
                /* Find */
                var temp=[];
                var pageArray = [];
                var phrase= [];
                first= phrase[0];
                    control= 0;
                            a = n + 1;
                            control=control+1;  // <== why do you increment this variable when you find the first word on a page?
                                    control=control+1;
                                    a=a+1;
                                } else break;
                                pageArray.push(p);
                                break;
                • 5. Re: Search PDF
                  natali.nac Level 1
                  The variable control gets increment when it's finds the first word of the string that should be found in the document.
                  var phrase= [];
                  first= phrase[0]; -> so first contains the word "string"
                              a = n + 1;
                  And when on a page we find this word, it means we get a hit and we should look if the next words are "to" and "search"
                  • 6. Re: Search PDF
                    When the page contains three times the word "string" and no other word you will get the value 3 for control.
                    • 7. Re: Search PDF
                      natali.nac Level 1
                      I have now put the reset of the control variable in the inner for loop:
                                control= 0;
                      and it seems to be working.
