Hey from Germany,
I just got my Lightroom 5 and tried to install it several times but I always end up getting this error code:
"An error occurred during the installation of assembly component
{5C21D397-1DA5-3749-8C1F-165F21DE9E3E}.
HRESULT: 0x800736FD. "
I tried to restart the computer, I tried to deinstall and reinstall the frameworks (like it said in solutions of the 1935 error).
Now I actually can't find ANY net.Frameworks anymore - I might ended up doing something wrong in this case, but if so, I don't know what I did wrong.
It might help if someone could explain what I need to do.
Your help would be appreciated, thank you!
Lea
Hello,
I don't know if it helps: But on my W8.1 system I have only -NET Framework 4.5.1 running.
Try to uncompress the setup using 7-zip. The setup itself contains two setups - one for 32bit one for 64bit. Try to start the correct version by hand.
http://support.microsoft.com/kb/976982/en-us
Addresses Microsoft Updates and .NET Framework issues. Make sure to restart your computer before applying any of these fixes. Also turn off all antivirus applications.
