For games is there any difference in using Starling in Flash and Flash Builder? I’ve used both but I would prefer to use Flash Professional because it prevents me from bouncing in and out of Flash Professional and Flash Builder. What are the advantages of using Flash Builder over Flash Professional, if any? Performance? If I use Flash Professional I will use sprite sheets and particle effects, etc., and will use object oriented techniques, with no code in the frames.
You should be able to use either one just fine. The differences (and your decision) comes down to the sort of editor you are most comfortable with. Flash Builder is much more code-oriented, of course but does nothing that cannot be accomplished using Flash Pro (aside from Flex, that is).
Thanks for the feedback Joseph. You have some great videos too!
I appreciate that - thank you!
