4 Replies Latest reply on Mar 20, 2015 1:20 AM by VeluVK
    Linked indesign file
    VeluVK
      Any one suggest the concept of linked InDesign file.
      Regards,
      Velu
        • 1. Re: Linked indesign file
          Steve Werner Adobe Community Professional & MVP
          Is there a question here? If so, you should restate it because I haven't the faintest idea of what you're asking.
          • 2. Re: Linked indesign file
            VeluVK Level 1
            Hi Steve,
            Thanks for your support.
            Suppose i need to modify Running head in first chapter (File 1). it may update all the files.
            I have around 20 files (20 chapters), same running read.
            Is there any option available in InDesign?
            Regards,
            Velu
            • 3. Re: Linked indesign file
              It depends on how the running head was created. If you used the Content Collector to Place and Link the header from chapter 1 into your other files I think it should update automatically, otherwise, if the header is on a master page, putting al the files in the same .indb Book file, setting chapter 1 as the source, and synchronizing the master pages should work.
              • 4. Re: Linked indesign file
                VeluVK Level 1
                Thanks for your reply.
                In First proof stages, i have used the book concept only. But in revision stages we are using the blacklining pluggin.
                Blacklining with InDesign book having some issues, book will automatically quitting any time.
                I will try the next option you suggested.
                Regards,
                Velu
