4 Replies Latest reply on Mar 4, 2015 7:53 AM by gkaiseril
    Converting excel formula into calculation script
    aishasuzan101 Level 1
      How to convert this excel formula into calculation script in pdf?
      =IF(K10="PRF1120",13,IF(K10="PRF1020",10,IF(K10="PRO1020",8,IF(K10="PRF1140",5,IF(K10="ACC 1020",3,IF(K10="PRO1080",4,""))))))
        • 1. Re: Converting excel formula into calculation script
          George_Johnson MVP & Adobe Community Professional
          The custom calculation script should be something like:
          // Get the value of the input field
          var sVal = getField("K10").valueAsString;
          // Set the value of this field depnding on the value of the input field
          switch (sVal) {
          case "PRF1120":
              event.value = 13;
              break;
          case "PRF1020":
              event.value = 10;
              break;
          // repeat for other possibilities
          default:
              event.value = "";  // Blank this field
          More information on the switch JavaScript statement is available in any decent JavaScript reference. Replace "K10" in the first line above with the actual name of the input field.
          • 3. Re: Converting excel formula into calculation script
            Hi.
            How about this formula?
            =DATE(YEAR(M9)+L9,MONTH(M9),DAY(M9))
            • 4. Re: Converting excel formula into calculation script
              Using your Excel cell names as the field names:
              // Excel =DATE(YEAR(M9)+L9,MONTH(M9),DAY(M9))
              // document level funtions;
              function GetField(cName) {
              // get field object with error checking;
              var oField = this.getField(cName);
              if(cName == null) app.alert("Error accessing field " + cName + "\nPlease check the existence of the field and its name.", 1, 0);
              return oField;
              } // end GetField function;
              function Scand(cForamt, cDateString) {
              // convert date string to a date object with error checking;
              var oDate = util.scand(cFormat, cDateString);
              if(oDate == null) app.alert("Error converting " + cDateStirng + " with format of " + cFormat +"\Please check the format of the date field", 0, 1);
              return oDate;
              } // end Scand function;
              // end document level functions;
              // custom JavaScript calculation for the target field;
              // format for dates;
              var cFormat = "d-mmm-yyyy";
              // field name for formatted input date;
              var cDateField = "M9";
              // field name for the number of years to add;
              var cAddYears = "L9";
              // get the field objects;
              var oDateField = GetField(cDateField);
              var oAddYears = GetField(cAddYears);
              event.value = ""; // clear the target field;
              // convert date string to date object;
              var oDate = Scand(cFormat, oDateField.valueAsString);
              // get the full year from the date object;
              var nFullYear = oDate.getFullYear();
              // add number of years to the full year;
              nFullYear += oAddYears.value;
              // rest the date object for the new year value;
              oDate.setFullYear(nFullYear);
              // set the target field with the new date;
              event.value = util.printd(cFormat, oDate);
              // end custom JavaScript calculation;
              More information about date and time calculations are included in the Acrobat JavaScript documentation available for free from Adobe and JavaScript documentation available for free from Mozilla Development.
