0 Replies Latest reply on Mar 4, 2015 5:37 AM by JC-TheSpaniard
    PDF Javascript Trusted DialogBox
    JC-TheSpaniard
      Hi there,
      I am currently learning to develop in Javascript within Acrobat and I am playing around with Trusted Dialog Boxes.  I have read and search everywhere and I can NOT seem to get my code to work.  This code came out of the Acrobat XI SDK API REFERENCE (page 149 - 151).  I am currently using Acrobat X Pro to develop.  So here are my questions:
      1. Why is it that this code does NOT work or show up the dialog box?
      2. How can I add the Tools Menu item?
      3. I tried adding a PUSH button with the code also but it does not work. Not sure why.
      4. Where am I suppose to add this script?  I am currently placing the script inside the Action Wizard as a Javascript.
      Code:
      myDialog = app.trustedFunction(function()
        app.beginPriv();
        var dialog = ANTrustPropagateAll({
        initialize:function(dialog) {
        this.data = {}; // An object to hold dialog data
        app.beginPriv();
        dialog.load({ "emai": "Email: " + identity.email });
        app.endPriv();
        commit:function (dialog) { // Called when OK pressed
        var results = dialog.store();
        console.println("Your name is " + results["name"] );
        this.data.name = results["name"];
        brws: function (dialog) {
        app.beginPriv();
        var oRetn = app.browseForDoc();
        if ( typeof oRetn != "undefined")
        this.data.oRetn = oRetn;
        app.endPriv();
        doDialog:function() {
        app.beginPriv();
        var retn = app.execDialog(this);
        app.endPriv();
        return retn;
        description: {
        name: "Open File & Populate Info Field",
        align_children: "align_left",
        elements:
        type: "view",
        elements:
        type: "view",
        align_children: "align_row",
        elements:
        type: "static_text",
        item_id: "name",
        type: "edit_text",
        alignment: "align_fill",
        width: 300,
        height: 20
        item_id: "emai",
        char_width: 25
        type: "gap",
        height: 10
        type: "view",
        elements:
        type: "button",
        item_id: "brws"
        type: "ok_cancel",
        ok_name: "Ok",
        cancel_name: "Cancel"
        app.endPriv();
        try { // Protect against user pressing the Esc key
        // After everything is set up, run the dialog box using the doDialog
        // function, defined in the object dialog.
        var retn = dialog.doDialog();
        app.beginPriv();
        // If the user clicked the Ok button and there is oRetn data we load
        // the requested file using app.openDoc(), a restricted method.
        if ( (retn == "ok") && dialog.data.oRetn ) {
        var oDoc = app.openDoc({
        cPath: dialog.data.oRetn.cPath,
        cFS: dialog.data.oRetn.cFS
        if ( !oDoc.info.Author )
        oDoc.info.Author = dialog.data.name;
        app.endPriv();
        } catch(e) {}
      And then the API reference says:
      This dialog box can be activated from a button or, more appropriately, from a menu item or a toolbar
      button. For example, place the following code in a User JavaScript file to add a menu item to the Tools
      menu.
      app.addMenuItem( { cName: "myDialog", cUser: "My Cool Dialog",
      cParent: "Tools", cExec: "myDialog()", nPos: 0 } );
      Not sure where to add the code to make a button or Menu item.  What does it mean "place the following code in a User JavaScript file to add a menu item to the Tools menu.
      Any help understanding this will be greatly appreciated!!!
