0 Replies Latest reply on Feb 15, 2007 11:53 PM by AshokSuccess
    Passing Variable through .INI file to Flash
    AshokSuccess Level 1
      Hello ,
      I stucked into one problem Actually I want to load the "Image " Dynamically inside flash without hard Coding it.
      I want that it should read the variable from any other file like .XML,.HTML,.INI etc so that user can change the name ...resulting the desire image to load inside Flash.
      I have used two code.
      loadVariables("VIPLOGO.png", "THEIMAGE");
      import flash.display.BitmapData
      /var container:MovieClip = createEmptyMovieClip("container", getNextHighestDepth());
      /var mcLoader:MovieClipLoader = new MovieClipLoader();
      mcLoader.addListener(this);
      mcLoader.loadClip("VIPLOGO.jpg",container);
      This loading the hard coded image file name. Which i dont want.
      and the other is
      var myStyle:TextField.StyleSheet = new TextField.StyleSheet();
      //myStyle.load("master.css");
      content_txt.styleSheet = myStyle;
      content_txt.multiline = true;
      content_txt.wordWrap = true;
      content_txt.html = true;
      var story:XML = new XML();
      story.ignoreWhite = true;
      story.load("images.html");
      story.onLoad = function() {
      content_txt.htmlText = story;
      its reading the HTML file but in this I have made the CSS file as comment and the problem coming with this is the image is not coming at desire place.
      I want any a simple method , So that a layman can also change the file name and that should effect the Flash Movie.
      Please help me out!
      Thanks!
