1 Reply Latest reply on Mar 5, 2015 12:55 PM by monstremoi
    I'm having major issues with closed captioning
    juans4806125
      I can't bring in SCC files. I'm working on a mac using 6 and cc and it's driving mad.
        • 1. Re: I'm having major issues with closed captioning
          monstremoi Adobe Employee
          Try this:
          Using PPRO CS 6.0
          1. Make sure that in the Program monitor, under the flag-menu options for the Program monitor (upper right icon), that "Closed Caption Display" is enabled and set to whatever your SCC is set to -- my SCC is CC1
          2. Select the Sequence you want captioning to appear in, and under "Sequence" menu in the main task bar, go to "Closed Captioning" and attach the SCC file
          You should see captions now when you scrub in the Sequence
          Good luck!
          CM
