4 Replies Latest reply on Mar 8, 2015 10:04 AM by akiva_atwood
    Transpose two hebrew words with nikud
    akiva_atwood Level 1
      Hi
      I have a hebrew paragraph with two words that need to be transposed:
      aaaaa {bbbbb} ccccc    ->  aaaaa ccccc {bbbbb}
      WIthout diacritics/nikud a simple grep in a script works fine:
      (\w+)( )(\{)(\w+)(\})    ->   $3$4$5 $1
      HOWEVER
      If there is nikud in the hebrew \w+ doesn't detect the words...
      I've tried using \X+ instead of \w+ but that doesn't always detect the closing } and continues until the NEXT occurance
      IS there a way to do this in a script?
        • 1. Re: Transpose two hebrew words with nikud
          Trevorׅ Adobe Community Professional
          Hi Akiva,
          Easy if you use the Unicode range.
          Find: ([\x{0590}-\x{05ff}]+) \{([\x{0590}-\x{05ff}]+)\} ([\x{0590}-\x{05ff}]+)
          Replace: $1 $3 {$2}
          Trevor
          • 2. Re: Transpose two hebrew words with nikud
            Hi Trevor
            Thanks -- that works great from the grep dialog -- but not in my code:
                app.findGrepPreferences = NothingEnum.NOTHING;
                   app.changeGrepPreferences = NothingEnum.NOTHING;
                   app.findGrepPreferences.findWhat="([\x{0590}-\x{05ff}]+)( )(\{)([\x{0590}-\x{05ff}]+)(\})";
                   app.changeGrepPreferences.changeTo="$3$4$5 $1";
                  x=doc.changeGrep();
                   alert(x.length+" changed");
                   app.findGrepPreferences.findWhat="(\{)([\x{0590}-\x{05ff}]+)(\})";
                   app.changeGrepPreferences.changeTo="\[$2\]";
                   app.changeGrepPreferences.appliedCharacterStyle = myDoc.characterStyles.itemByName("ChumashKiri");
                 x=doc.changeGrep();
            Any idea why not?
            • 3. Re: Transpose two hebrew words with nikud
              You need to escape the escapes when you put it in code
              var doc = app.activeDocument;
              app.findGrepPreferences.findWhat="([\\x{0590}-\\x{0600}]+) \\{([\\x{0590}-\\x{0600}]+)\\} ([\\x{0590}-\\x{0600}]+)";
              app.changeGrepPreferences.changeTo="$1 $3 {$2}";
              var x=doc.changeGrep();
              Use the same principle for the second grep. (I left it for you to practice )
              I don't know why you are bracketing the space and curly brackets instead of just using the simple replacement as I do.
              Regards
              Trevor
              • 4. Re: Transpose two hebrew words with nikud
                Thanks -- I always forget to escape the escape
                Re brackets: Habit. I start off verbose (which is why everything is bracketed) -- then combine once it's working
