1 Reply Latest reply on Mar 5, 2015 1:50 PM by Sandee Cohen
    Why does consecutive figure numbering break when using anchored and in-lin objects
    JFriz Level 1
      I have an ID CC2014 document that contains graphics with figure numbers associated (using a defined paragraph style - numbered list - continue from previous) and when I place these into the flow of the document with a wrap associated to them they maintain the consecutive numbering that was set up in the figure style sheet. However when a table or graphic is placed in-line with the text (anchored graphic box or inserted table) the consecutive figure numbering doesn't continue, it restarts as #1. The next anchored or inserted item then sees this figure number and follows as if the list was restarted.  What is up?
      I have found that if all items are used as wrap graphics or separate text/table boxes the figure numbering functions as it should.
      Is this a glitch?
