2 Replies Latest reply on Mar 5, 2015 6:37 PM by alexcesss
    Cuáles son los requerimientos de sistema para Premiere Elements 12
    alexcesss
      Actualmente me desempeño como Media Mentor del Programa Adobe Youth Voices en la Ciudad de México. Ya que algunos de los sitios en los  que trabajamos no cuentan con máquinas muy potentes me gustaría saber si hay una tabla comparativa como está: FAQ: What OS does Photoshop Elements run on, or Will PSE run on my computer? para !PremiereElements, nuestra organización cuenta con licencias para PePe en las versiones 9, 10, 11 y 12 y sería útil tener una tabla cómo la anterior para poder saber que versión distribuir entre los diferentes sitios.
      Muchas gracias por su atención.
      Alejandro Jiménez
        • 1. Re: Cuáles son los requerimientos de sistema para Premiere Elements 12
          A.T. Romano Level 7
          Alejandro Jimenez
          For Premiere Elements System Requirements for versions 13 to 8 and the older versions, please see the Adobe Document
          System requirements | Adobe Premiere Elements
          Regarding what versions will or will not work on certain operating systems...I would question even your Photoshop Elements FAQ reference.
          What Adobe has not tested is not the same the impression that the program does not work on a certain operating system it has designated as " - ".
          I have not seen a Premiere Elements document comparable to this FAQ document that you present for Photoshop Elements.
          I have found no problem installing and running Premiere Elements 4, 7, 8.0/8.0.1,  9.0/9.0.1, 10, 11, 12/12.1, 13/13.1 on Windows 7 Professional SP1 64 bit or Windows 8.1 64 bit.
          The version updates, if available, should be used to give special obvious features as well as other less obvious ones.
          In the case of the current version, Premiere Elements 13/13.1, Windows XP, Windows Vista, and OSX 10.7 are not supported. Interestingly, I have found that you can
          download the Premiere Elements 13 tryout from Adobe to a Windows XP computer, but you cannot install it.
          Also, on a comparative basis, Premiere Elements version 32 versus 64 bit application
          Windows
          Premiere Elements 10, 11, 12, and 13 are 64 bit applications only when they are specifically on Windows 7, 8, or 8.1 64 bit computer.
          Premiere Elements earlier then 10 are 32 bit applications whether they are run on Windows 32 bit computer or Windows 64 bit computer.
          Mac
          Premiere Elements 9 was the first version to be offered for Mac as well as Windows.
          Premiere Elements Mac was not available as a 64 bit application until version 11 - and with Mac 64 processor.
          Miscellaneous
          Premiere Elements as a 32 bit application will block you from importing still images beyond a certain total pixel count.
          Lots of other details, but let us start with these.
          Please let us know if you need clarification on any of the above.
          ATR
          • 2. Re: Cuáles son los requerimientos de sistema para Premiere Elements 12
            alexcesss Level 1
            A.T. Romano,
            Thanks your answer was both fast and complete as I need.
            Best,
