13 Replies Latest reply on Mar 6, 2015 6:37 AM by Jean-Claude Tremblay
    Duplicate object into multiple selected frame
    Jean-Claude Tremblay User Group Manager
      I’m looking for a script that will duplicate the selected object or the content of the clipboard into multiple selected layers inside a document.
      I have not find any discussions around this, but I’m asking if anyone have already seen such script.
      Jean-Claude
        • 1. Re: Duplicate object into multiple selected frame
          Jump_Over Level 5
          "multiple selected layers" could be a main issue here, cause - as far as I know - script is not able to read UI panels states (except active property).
          But if you may find other condition rule...
          Jarek
          • 2. Re: Duplicate object into multiple selected frame
            Kai Rübsamen Level 4
            Just a idea: What if the user select the layers not in the normal panel, instead he click on checkboxes in a dialog?
            –Kai
            • 3. Re: Duplicate object into multiple selected frame
              Jump_Over Level 5
              Hi Kai,
              If so - good condition is found.
              Jarek
              • 4. Re: Duplicate object into multiple selected frame
                Hi Jarek,
                what do you mean with good condition?
                I would display a dialog with checkboxes, based on the layers names in the acual document. If the checkboxes are checked, the selected object will be duplicated on these layers.
                We had a similiar goal some weeks ago with checked layers in ai-files in our german forum.
                –Kai
                • 5. Re: Duplicate object into multiple selected frame
                  Jump_Over Level 5
                  Hi Kai,
                  I ment the way code could be based on that input and output data are defined definitely.
                  A dialog with check boxes is a good solution.
                  Jarek
                  • 6. Re: Duplicate object into multiple selected frame
                    O.K. lets wait what Jean-Claude thinks about a dialog and if he wants to duplicate only single objects, multiple objects, groups …
                    • 7. Re: Duplicate object into multiple selected frame
                      My first idea was indeed a dialog with layers names in it. Much quicker than having to turn on/off visibilities of layers, than return to original stay of document.
                      For the objects, it could be a single or multiple object or groups.
                      • 8. Re: Duplicate object into multiple selected frame
                        @Jean-Claude – that is all doable, also a "deluxe" version where the dialog is a panel constantly updating the list of layers, if you add and remove, change order or turn on/off visibility.
                        For your basic need, the following snippet in ExtendScript should be sufficient.
                        All selected objects will be duplicated to all layers that are visible and not locked:
                        var mySel = app.selection;
                        var myLayers = app.documents[0].layers.everyItem().getElements();
                        for(var s=0;s<mySel.length;s++){
                            var layerOfSelection = mySel[s].itemLayer;
                            for(var n=0;n<myLayers.length;n++){
                                if(
                                    myLayers[n] !== layerOfSelection
                                    && myLayers[n].visible === true
                                    && lmyLayers[n].locked === false
                                    mySel[s].duplicate(myLayers[n]);
                        Uwe
                        • 9. Re: Duplicate object into multiple selected frame
                          Hi Guys,
                          I rewrite Hans Haeslers script a bit. In a first step it will only work with single selected items and will not check, if the selected layers are locked or hidden:
                          // duplicate on different layers _b01
                          // vorbeugenderweise das Anzeigen von Dialogen aktivieren
                          app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
                          // prüfen, ob ein Dokument geöffnet ist
                          if ( app.documents.length == 0 ) {
                              alert ( "Open a document" );
                              exit();
                          // die Auswahl speichern ...
                          if ( app.selection.length == 1 ) {
                              var curSel = app.selection[0];
                          else {
                              alert ( "Warning\rWorks only with one selected item at the moment" );
                              exit();
                          var curDoc = app.activeDocument;
                          var allLayers = curDoc.layers;
                          var nLayers = allLayers.length;
                          // eventuell vorhandene Dialoge entfernen
                          try {
                              app.dialogs.everyItem().destroy();
                          catch (e) {
                          var layerNames = new Array();
                          for ( var i = 0; i < nLayers; i++ ) {
                              layerNames.push( allLayers[i].name );
                          try {
                          catch (e) {
                          // den Dialog vorbereiten ...
                          var dlogCheckList = new Array();
                          var aDialog = app.dialogs.add({ name: "Duplicate object to selected layers", canCancel: true });
                          with ( aDialog ) {
                              with ( dialogColumns.add() ) {
                                  with ( dialogRows.add() ) {
                                      staticTexts.add({ staticLabel: "active = duplicate"} );
                                      for ( var n = 0; n < nLayers; n++ ) {
                                          with (dialogRows.add()) {
                                              dlogCheckList.push( checkboxControls.add({ staticLabel: layerNames[n] }));
                          // ... anzeigen und die Wahl des Anwenders anwenden
                          if ( aDialog.show() == true ) {
                              for ( var k = 0; k < dlogCheckList.length; k++ ) {
                                  var curCheckBox = dlogCheckList[k];
                                  if ( curCheckBox.checkedState ) {
                                      var curLayer = curDoc.layers.itemByName( layerNames[k] );
                                      curSel.duplicate( curLayer );
                              aDialog.destroy();
                          else {
                              aDialog.destroy();
                          Kai
                          • 10. Re: Duplicate object into multiple selected frame
                            @Uwe Your snippets fail/stop at if( each time. Thanks!
                            @Kai Wow! This works on a single group object too. Might be enough for my need.
                            • 11. Re: Duplicate object into multiple selected frame
                              Jean-Claude try the following one:
                              1. Should work with a single object, multiple objects, group
                              2. Should alert a warning, if you select nothing or select some text
                              3. Will not honor, if layers are hidden or locked
                              Does it work for you?
                              // duplicate on different layers _b02
                              // by Kai Rübsamen, credits to Hans Haesler
                                  alert ( "Warning\rOpen a document!" );
                                  exit();
                              var allSel = app.selection;
                              var nItems = allSel.length;
                              // und prüfen
                              if ( !nItems ) {
                                  alert ( "Warning\rSelect something!" );
                                  exit();
                              if ( nItems == 1 && app.selection[0].hasOwnProperty("baseline") ) {
                                  alert ( "Warning\rDoes not work with text. Select only frames!" );
                                  exit();
                              try {
                              catch (e) {
                              try {
                              catch (e) {
                              with ( aDialog ) {
                                          for ( var i = nItems-1; i >= 0; i-- ) {
                                              var curSel = allSel[i];
                                  aDialog.destroy();
                              else {
                                  aDialog.destroy();
                              –Kai
                              • 12. Re: Duplicate object into multiple selected frame
                                @Jean-Claude – sorry, a little typo sneaked in.
                                I had an additional character in the the variable name of myLayers inside of the if statement.
                                Here the code again:
                                        if(
                                            && myLayers[n].locked === false
                                Uwe
                                • 13. Re: Duplicate object into multiple selected frame
                                  Kai & Uwe, both solutions works perfectly. Both are useful depending on specific need and situation.
                                  Thanks a lot guys for your help and generosity. Hope this can be useful to others too.
