11 Replies Latest reply on Mar 6, 2015 4:38 AM by RoninEdits
    Video/Audio cut out
    andrews58958643 Level 1
      Hi there,
      I am trying to edit a video file that is in .mov format ( see bellow a screen shot of the original file ):
      It says it has 01:11:31 duration, but when i enter it in Premier it show's up only to 01:08:10 ( see bellow ), so the video and audio cuts at this point. Any ideas why this is happening ?
        • 1. Re: Video/Audio cut out
          RoninEdits Most Valuable Participant
          if you open the file in a media player does it play to the end? if so, does do anything funny around 1:08:10 as it plays?  its possible the file is damaged and premiere cannot read it all, or read past that damaged spot, so it reads as much as it can.
          • 2. Re: Video/Audio cut out
            Hi Ronin,
            I thought about that. In media players it works fine. No glitch or anything.
            • 3. Re: Video/Audio cut out
              does this happen with any other media or just this one file? is this file on an external hdd or sd card? if so can you try copying it to your computer?  if its h264, you could try to re-wrap it using avidemux. if there is some hidden problem with the file, that would fix or show it.
              • 4. Re: Video/Audio cut out
                Hi Ronin and thank you so much for your answers.
                The file is h264, it's on my local drive. I get the same issue from time to time with .mov files i get for editing. I convert them to h264 and that normally solves the issue.
                If i try to import the original .mov file in Premier you can see bellow what happens. The video and audio are totally out of sync.
                • 5. Re: Video/Audio cut out
                  if those are variable fps video's, premiere wont like them. if you need to check, you can use mediainfo  and convert to constant fps using handbrake.
                  • 6. Re: Video/Audio cut out
                    I installed the mediainfo. I also attached the video in question, maybe you can get a better idea if you have it there. It's 88 mb - https://db.tt/KRQTs5yR
                    • 7. Re: Video/Audio cut out
                      to get a better view, click on the wrench icon to open preferences, and change the output format to "text".
                      should look like this:  (notice it is variable, so you will need to convert to constant with handbrake)
                      Video
                      Format                                : AVC
                      Format/Info                          : Advanced Video Codec
                      Format profile                       : High@L4.0
                      Format settings, CABAC       : No
                      Format settings, ReFrames   : 2 frames
                      Codec ID                              : avc1
                      Codec ID/Info                        : Advanced Video Coding
                      Duration                               : 1h 8mn
                      Bit rate mode                        : Variable
                      Bit rate                                 : 34.8 Kbps
                      Maximum bit rate                  : 12.7 Mbps
                      Width                                   : 1 920 pixels
                      Height                                  : 1 080 pixels
                      Display aspect ratio               : 16:9
                      Frame rate mode                : Variable
                      Frame rate                            : 0.400 fps
                      Minimum frame rate               : 0.020 fps
                      Maximum frame rate              : 31.579 fps
                      Color space                           : YUV
                      Chroma subsampling              : 4:2:0
                      Bit depth                               : 8 bits
                      Scan type                             : Progressive
                      Bits/(Pixel*Frame)                 : 0.042
                      Stream size                          : 17.0 MiB (19%)
                      Encoded date                        : UTC 2015-03-05 20:21:27
                      Tagged date                          : UTC 2015-03-05 20:21:45
                      • 8. Re: Video/Audio cut out
                        I understand.
                        I installed Handbrak.
                        Do you think you can help me out with this? Have no idea what setting i should input there...
                        • 9. Re: Video/Audio cut out
                          under the video tab, choose constant instead of variable.
                          i had it do a quick convert and it cut off the end of the video. there is something wrong with that video, thats why premiere cuts it off early too. i was able to open the file up in audacity to extract the audio, you might have to do that to get the audio working...
                          • 10. Re: Video/Audio cut out
                            Same issue in Premier. Sees only until 01:08:15
                            General
                            Complete name                            : F:\Completed\Flo\Assets\05-03-2015\1.mp4
                            Format                                   : MPEG-4
                            Format profile                           : Base Media / Version 2
                            Codec ID                                 : mp42
                            File size                                : 178 MiB
                            Duration                                 : 1h 11mn
                            Overall bit rate mode                    : Variable
                            Overall bit rate                         : 347 Kbps
                            Tagged date                              : UTC 2015-03-06 12:23:46
                            Writing application                      : HandBrake 0.10.0 2014112200
                            Video
                            Format                                   : AVC
                            Format profile                           : High@L4.1
                            Format settings, CABAC                   : Yes
                            Format settings, ReFrames                : 4 frames
                            Codec ID                                 : avc1
                            Duration                                 : 1h 8mn
                            Bit rate                                 : 109 Kbps
                            Width                                    : 1 650 pixels
                            Display aspect ratio                     : 3:2
                            Frame rate mode                          : Constant
                            Frame rate                               : 25.000 fps
                            Color space                              : YUV
                            Bit depth                                : 8 bits
                            Bits/(Pixel*Frame)                       : 0.002
                            Stream size                              : 53.0 MiB (30%)
                            Writing library                          : x264 core 142 r2479 dd79a61
                            Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
                            Color primaries                          : BT.709
                            Transfer characteristics                 : BT.709
                            Matrix coefficients                      : BT.709
                            Color range                              : Limited
                            Audio #1
                            Format                                   : AAC
                            Format/Info                              : Advanced Audio Codec
                            Format profile                           : LC
                            Codec ID                                 : 40
                            Duration                                 : 1h 11mn
                            Bit rate                                 : 139 Kbps
                            Channel(s)                               : 2 channels
                            Channel(s)_Original                      : 1 channel
                            Channel positions                        : Front: C
                            Sampling rate                            : 44.1 KHz
                            Compression mode                         : Lossy
                            Stream size                              : 70.9 MiB (40%)
                            Title                                    : Mono / Mono
                            Audio #2
                            Format                                   : AC-3
                            Format/Info                              : Audio Coding 3
                            Mode extension                           : CM (complete main)
                            Format settings, Endianness              : Big
                            Codec ID                                 : ac-3
                            Duration                                 : 1h 11mn
                            Bit rate mode                            : Constant
                            Bit rate                                 : 96.0 Kbps
                            Channel(s)                               : 1 channel
                            Bit depth                                : 16 bits
                            Stream size                              : 49.1 MiB (28%)
                            Title                                    : Mono / Mono
                            • 11. Re: Video/Audio cut out
                              thats what i was saying in my last post. variable fps is a problem with premiere, but the video is also damaged or was created improperly.
