1 Reply Latest reply on Mar 6, 2015 5:28 AM by Laubender
    convertir estilo de parrafo a objeto anclado
    oddeia Level 1
      Hola a todos!
      Necesito convertir un estilo de parrafo a un objeto anclado, tengo cientos en cada capítulo del libro
      ¿Se podría hacer mediante script?
      ¿Alguien me puede ayudar?
      Muchas Gracias
        • 1. Re: convertir estilo de parrafo a objeto anclado
          @Oddela – there already should be some script snippets doing this (more or less). The methods identifying the right text ranges might vary a bit. Some work with special strings before and after the text as identifier, some work with footnotes as identifier, some work with character styles, some with paragraph styles. Some would do it, if you exchange your own names for paragraph styles, character styles and object styles. That means: You have to read the code and understand where to change parameters for your special needs.
          Here one example by Kai Rübsamen on hilfdirselbst.ch that is using special content strings  as identifiers for the text, that define exactly what should go into the anchored text frame and what should not:
          Texte automatisiert in Marginalien ändern
          Kai Rübsamen
          Texte automatisiert in Marginalien ändern - Adobe InDesign Skriptwerkstatt -  HilfDirSelbst.ch - Forum
          There are many more examples out in the web…
          Uwe
