1 Reply Latest reply on Mar 6, 2015 9:48 AM by Willi Adelberger
    installing from MSI
    wardj1906
      I created an MSI using AAMEE for InDesign (CS6)   When I click on the MSI, the install begins and after 30 seconds or so, the install rolls back and quits.  However, if I use the same source files and click setup.exe and use the GUI from Adobe and select "Install with a serial number," InDesign installs perfectly with no issues.
      I need the MSI so I can deploy InDesign with the CS6 suite via SCCM.  All of the other components install via SCCM except InDesign, and it appears that the MSI is the problem.
      Any assistance would be greatly appreciated.
