1 Reply Latest reply on Mar 6, 2015 11:37 AM by Peter Kahrel
    in text frame enumeration
    hamdifem
      while in a text frame some numbers again I want to sort
      I have written a code for it
      but completely fails
      please help
      before
      2.          auto se none furor patidit
      3.          bus se none furor patidit
      7.          car se none furor patidit
      after
      1.          auto se none furor patidit
      2.          bus se none furor patidit
      3.          car se none furor patidit
      This process is not for the entire document
      While in a text frame or text frame is selected I want
      var sno = 0;
      app.findGrepPreferences = app.changeGrepPreferences = null;
      app.findGrepPreferences.findWhat = "^\\d+.\\t";
      for(var i = 0; i < app.selection.length; ++i) {
      var b = app.selection[i].parentStory.textFrames; //??
      for(var i = 0; i < b.length; ++i) {
      app.changeGrepPreferences.changeTo  = (++sno).toString() + ".\t";
      b[i].changeGrep();
        • 1. Re: in text frame enumeration
          Peter Kahrel Adobe Community Professional & MVP
          You were looking for the wrong text. Look just for the initial number, ^\d+, nothing else. Then use the loop counter to change the numbers, as in this code:
          app.findGrepPreferences = null;
          app.findGrepPreferences.findWhat = '^\\d+'
          numbers = app.selection[0].parentStory.findGrep();
          for (i = numbers.length-1; i >= 0; i--) {
              numbers[i].contents = String(i+1)
          Select the frame that holds your text and run the script.
          Peter
